Hello,
I am making a project to track the movement of a users hand by using the MPU6050. I’ve been using Jeff Rowbergs library to get the thing working and have started to look into some of the functions he uses, mainly so I can do some other things with the data.
I’m no good at C programming and wanted to know how the program knows which function to run from the .cpp file when the .ino file uses the following function call:
mpu.dmpGetQuaternion(&q, fifoBuffer);
When I look in the .cpp file there are 3 functions, all with the same name and data types! Is it first come first served ? or something else
uint8_t MPU6050::dmpGetQuaternion(int32_t *data, const uint8_t* packet) {
// TODO: accommodate different arrangements of sent data (ONLY default supported now)
if (packet == 0) packet = dmpPacketBuffer;
data[0] = (((uint32_t)packet[0] << 24) | ((uint32_t)packet[1] << 16) | ((uint32_t)packet[2] << 8) | packet[3]);
data[1] = (((uint32_t)packet[4] << 24) | ((uint32_t)packet[5] << 16) | ((uint32_t)packet[6] << 8) | packet[7]);
data[2] = (((uint32_t)packet[8] << 24) | ((uint32_t)packet[9] << 16) | ((uint32_t)packet[10] << 8) | packet[11]);
data[3] = (((uint32_t)packet[12] << 24) | ((uint32_t)packet[13] << 16) | ((uint32_t)packet[14] << 8) | packet[15]);
return 0;
uint8_t MPU6050::dmpGetQuaternion(int16_t *data, const uint8_t* packet) {
data[0] = ((packet[0] << 8) | packet[1]);
data[1] = ((packet[4] << 8) | packet[5]);
data[2] = ((packet[8] << 8) | packet[9]);
data[3] = ((packet[12] << 8) | packet[13]);
return 0;
uint8_t MPU6050::dmpGetQuaternion(Quaternion *q, const uint8_t* packet) {
int16_t qI[4];
uint8_t status = dmpGetQuaternion(qI, packet);
if (status == 0) {
q -> w = (float)qI[0] / 16384.0f;
q -> x = (float)qI[1] / 16384.0f;
q -> y = (float)qI[2] / 16384.0f;
q -> z = (float)qI[3] / 16384.0f;
return 0;
return status; // int16 return value, indicates error if this line is reached
Thanks
