MPU6050 get values for acceleration/deceleration/constant
Hi all, I'm trying to make a servo respond to data from an MPU6050. I'd like to be able to write a value to the servo based on 3 conditions:
  1. If the gyro is sensing acceleration then write a predefined value to the servo
  2. If the gyro is sensing deceleration then write a predefined value to the servo
  3. If the gyro is sensing neither (i.e traveling at a constant speed) then write a predefined value to the servo
Each circumstance has a different value written to the servo.
In my example below I'm trying to compare currentValue with previousValue.
Is there a better way to do this than what I have here? All I want is to be able to distinguish between the three states and react the servo accordingly.
I've reduced the ZAxGForce value from / 1000 to / 100 in order to have a larger value to play with
Any help is greatly appreciated!!
This is my first post so forgive me/let me know if I'm breaking any of the rules.
Thanks in advance!
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MPU6050.h"
#include <Servo.h>
Servo myservo;
Servo myservo2;// create servo object to control a servo
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 accelgyro;
//MPU6050 accelgyro(0x69); // <-- use for AD0 high
int16_t ax, ay, az;
int16_t gx, gy, gz;
// uncomment "OUTPUT_READABLE_ACCELGYRO" if you want to see a tab-separated
// list of the accel X/Y/Z and then gyro X/Y/Z values in decimal. Easy to read,
// not so easy to parse, and slow(er) over UART.
#define OUTPUT_READABLE_ACCELGYRO
// uncomment "OUTPUT_BINARY_ACCELGYRO" to send all 6 axes of data as 16-bit
// binary, one right after the other. This is very fast (as fast as possible
// without compression or data loss), and easy to parse, but impossible to read
// for a human.
//#define OUTPUT_BINARY_ACCELGYRO
#define LED_PIN 13
bool blinkState = false;
int previousValue = 0;
int currentValue = 0;
    // join I2C bus (I2Cdev library doesn't do this automatically)
        Wire.begin();
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
    #endif
     myservo.attach(9);  // attaches the servo on pin 9 to the servo object
     myservo2.attach(8);
    // initialize serial communication
    // (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
    // it's really up to you depending on your project)
    Serial.begin(38400);
    // initialize device
    Serial.println("Initializing I2C devices...");
    accelgyro.initialize();
    // verify connection
    Serial.println("Testing device connections...");
    Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
    // use the code below to change accel/gyro offset values
    Serial.println("Updating internal sensor offsets...");
    // -76  -2359 1688  0 0 0
    Serial.print(accelgyro.getXAccelOffset()); Serial.print("\t"); // -76
    Serial.print(accelgyro.getYAccelOffset()); Serial.print("\t"); // -2359
    Serial.print(accelgyro.getZAccelOffset()); Serial.print("\t"); // 1688
    Serial.print(accelgyro.getXGyroOffset()); Serial.print("\t"); // 0
    Serial.print(accelgyro.getYGyroOffset()); Serial.print("\t"); // 0
    Serial.print(accelgyro.getZGyroOffset()); Serial.print("\t"); // 0
    Serial.print("\n");
    accelgyro.setXGyroOffset(220);
    accelgyro.setYGyroOffset(76);
    accelgyro.setZGyroOffset(-85);
    Serial.print("\n");
    // configure Arduino LED for
    pinMode(LED_PIN, OUTPUT);
int ZAxGForce = 0;
    // read raw accel/gyro measurements from device
    accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
    // these methods (and a few others) are also available
    //accelgyro.getAcceleration(&ax, &ay, &az);
    //accelgyro.getRotation(&gx, &gy, &gz);
    #ifdef OUTPUT_READABLE_ACCELGYRO
        // display tab-separated accel/gyro x/y/z values
        Serial.print("a/g:\t");
//        Serial.print(ax); Serial.print("\t");
//        Serial.print(ay); Serial.print("\t");
        Serial.print(az); Serial.print(" | ");Serial.print("G Force ZAx: "); Serial.println();
        ZAxGForce = az / 100;
//        Serial.print(gx); Serial.print("\t");
//        Serial.print(gy); Serial.print("\t");
//        Serial.println(gz);
    #endif
    #ifdef OUTPUT_BINARY_ACCELGYRO
        Serial.write((uint8_t)(ax >> 8)); Serial.write((uint8_t)(ax & 0xFF));
        Serial.write((uint8_t)(ay >> 8)); Serial.write((uint8_t)(ay & 0xFF));
        Serial.write((uint8_t)(az >> 8)); Serial.write((uint8_t)(az & 0xFF));
        Serial.write((uint8_t)(gx >> 8)); Serial.write((uint8_t)(gx & 0xFF));
        Serial.write((uint8_t)(gy >> 8)); Serial.write((uint8_t)(gy & 0xFF));
        Serial.write((uint8_t)(gz >> 8)); Serial.write((uint8_t)(gz & 0xFF));
    #endif
    // blink LED to indicate activity
    blinkState = !blinkState;
    digitalWrite(LED_PIN, blinkState);
int currentValue = ZAxGForce;
    if (previousValue < currentValue){
      Serial.println("AIRBRAKE");
      myservo.write(130);
      myservo2.write(130);
    if (previousValue > currentValue){
      Serial.println("DRS!");
      myservo.write(80);
      myservo2.write(80);
     if (previousValue == currentValue){
    Serial.println("ACTIVE!");
    myservo.write(105);
    myservo2.write(105);
  Serial.print("Previous value  ");
  Serial.println(previousValue);
  Serial.print("Current value  ");
  Serial.println(currentValue);
  previousValue = currentValue;
The MPU6050 has two sensors, and three axes, X, Y and Z.
The gyro measures rate of rotation about X, Y and Z.
The accelerometer measures acceleration along X, Y and Z, including the acceleration due to gravity in the vertical direction.
For acceleration you want the accelerometer, not the gyroscope.
By 'acceleration' do you mean "increasing speed forward"? If so, which axis is pointing "forward"? Usually, that would be X or Y.
  // 1. If the gyro is sensing acceleration then write
  // a predefined value to the servo
  if (ax > 10)
    myServo.write(ServoValueAcceleration);
  // 2. If the gyro is sensing deceleration then write a
  // predefined value to the servo
  else if (ax < -10)
    myServo.write(ServoValueDeceleration);
  // 3. If the gyro is sensing neither (i.e traveling at a
  // constant speed) then write a predefined value to the servo
    myServo.write(ServoValueSteady);
