MPU6050 GY-521 no sense output
Hi All,
I am not an expert of electronics so don't judge me :D.
I recently got an arduino nano which is now connected to a GY-521 gyro/accelerometer. I indeed scanned with the i2cscanner script and the sensor is detected. Whenever I use the basic scripts from the arduino playground I get raw values, which I can actually "read".
Recently, I installed the i2cdevlib since I wanted to try the teapot example. Everything was ok no weird message during compilation and I indeed installed all the libraries for arduino and processing. I do not have any error message during compilation, however, first the plane doesn't move when I move the sensor and if I open the serial monitor i get these no sense values:
K58¨ò¬e(åº"ºeÊ(wJêãn¸fÊe%ʦ
Any help? :slight_smile:
Thanks,
G
Make sure the baud rate of the serial monitor matches the baud rate in Serial.begin().
Do you mean the number 115200? :smiley:
Yes they do. I didn't change anything so far.
Sorry I thought you meant the one in processing. Actually now I can read the output in the serial monitor. THANKS!
Any idea why my plane is not moving?
So... If i press the reset button on the nano I get this
Send any character to begin DMP programming and demo:
Initializing I2C devices...
Testing device connections...
MPU6050 connection successful
but still the plane is not responding.
Can you put print statements in the processing code to see if you are getting data from the Arduino?
How do I do that?
In the Processing IDE, the bottom part of the window is the console. You can use print( a_variable); or print("a string"); to print out troublshooting data to the console. Put a print after the serial reception portion to see what is actually going into the Processing program
Ok I changed the serial port to a specific serial port with this line:
String portName = "/dev/tty.wchusbserialfa130";
and then put:
println(portName)
and I get the correct port. If i try to open the serial monitor it say "busy", which should mean that it's being used for the connection with processing. However, no plane moving.
I also tried the reset button in every possible combination with play in processing.
Any idea what's going on?
Thanks for the help.
You are right that you can not have serial monitor and processing connected to the serial port at the same time. You can put diagnostic prints in the processing program to try and see if data is coming into the processing serial port. Check where the serial port is set up in setup() of the processing program to make sure the right port and baud rate is set.
Hey guys if you have any problems with the MPU 6050 Please check my tutorial here ! I go through step by step and get the teapot Demo working ! I also have the Dev libraries ready for download!
Thanks guys!
Odin
Thanks! The problem was that i didn't uncomment OUTPUT_TEAPOT... Newbie! I also suggest this tutorial
:slight_smile: Now I am trying to connect a led that blinks when critical pitch/roll angles are detected.
I tried to add a simple if ( ypr[1] < y && ypr[1] > y ) but i only get overflow FIFO message back.
Any help or hint?
Thanks
