Hello Guys!
i am trying to makeing work an MPU6050, a few days ago..yes..
i use a lot of tutorials on the web, and the libraries, but is not working yet..
maybe the mpu 6050 is broken?
this is one of the errors..
nvalid library found in C:\Program Files (x86)\Arduino\libraries\i2CScanner: C:\Program Files (x86)\Arduino\libraries\i2CScanner
Invalid library found in C:\Program Files (x86)\Arduino\libraries\MPU6050_calibration: C:\Program Files (x86)\Arduino\libraries\MPU6050_calibration
Invalid library found in C:\Program Files (x86)\Arduino\libraries\i2CScanner: C:\Program Files (x86)\Arduino\libraries\i2CScanner
i remove all the folders in the arduino library, and install other from here
and the error now is!!...
In file included from C:\Program Files (x86)\Arduino\libraries\MPU6050\Examples\MPU6050_DMP6\MPU6050_DMP6.ino:48:0:
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h: In member function 'uint8_t MPU6050::dmpGetAccel(int32_t*, const uint8_t*)':
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:580:31: warning: left shift count >= width of type [enabled by default]
data[0] = ((packet[28] << 24) + (packet[29] << 16) + (packet[30] << 8) + packet[31]);
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:580:52: warning: left shift count >= width of type [enabled by default]
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:581:31: warning: left shift count >= width of type [enabled by default]
data[1] = ((packet[32] << 24) + (packet[33] << 16) + (packet[34] << 8) + packet[35]);
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:581:52: warning: left shift count >= width of type [enabled by default]
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:582:31: warning: left shift count >= width of type [enabled by default]
data[2] = ((packet[36] << 24) + (packet[37] << 16) + (packet[38] << 8) + packet[39]);
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:582:52: warning: left shift count >= width of type [enabled by default]
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h: In member function 'uint8_t MPU6050::dmpGetQuaternion(int32_t*, const uint8_t*)':
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:604:30: warning: left shift count >= width of type [enabled by default]
data[0] = ((packet[0] << 24) + (packet[1] << 16) + (packet[2] << 8) + packet[3]);
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:604:50: warning: left shift count >= width of type [enabled by default]
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:605:30: warning: left shift count >= width of type [enabled by default]
data[1] = ((packet[4] << 24) + (packet[5] << 16) + (packet[6] << 8) + packet[7]);
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:605:50: warning: left shift count >= width of type [enabled by default]
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:606:30: warning: left shift count >= width of type [enabled by default]
data[2] = ((packet[8] << 24) + (packet[9] << 16) + (packet[10] << 8) + packet[11]);
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:606:50: warning: left shift count >= width of type [enabled by default]
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:607:31: warning: left shift count >= width of type [enabled by default]
data[3] = ((packet[12] << 24) + (packet[13] << 16) + (packet[14] << 8) + packet[15]);
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:607:52: warning: left shift count >= width of type [enabled by default]
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h: In member function 'uint8_t MPU6050::dmpGetGyro(int32_t*, const uint8_t*)':
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:637:31: warning: left shift count >= width of type [enabled by default]
data[0] = ((packet[16] << 24) + (packet[17] << 16) + (packet[18] << 8) + packet[19]);
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:637:52: warning: left shift count >= width of type [enabled by default]
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:638:31: warning: left shift count >= width of type [enabled by default]
data[1] = ((packet[20] << 24) + (packet[21] << 16) + (packet[22] << 8) + packet[23]);
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:638:52: warning: left shift count >= width of type [enabled by default]
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:639:31: warning: left shift count >= width of type [enabled by default]
data[2] = ((packet[24] << 24) + (packet[25] << 16) + (packet[26] << 8) + packet[27]);
C:\Program Files (x86)\Arduino\libraries\MPU6050/MPU6050_6Axis_MotionApps20.h:639:52: warning: left shift count >= width of type [enabled by default]
Multiple libraries were found for "I2Cdev.h"
Used: C:\Users\tanakabuki\Documents\Arduino\libraries\I2Cdev
Not used: C:\Program Files (x86)\Arduino\libraries\I2Cdev
any idea?
thanks for advanced!
