hello eveyone, today i use kalman filter with mpu6050 and all i get is only roll and pitch axis. but for my project i need to read yaw axis but i don't know how to add yaw axis to kalman filter.
/* Copyright (C) 2012 Kristian Lauszus, TKJ Electronics. All rights reserved.
This software may be distributed and modified under the terms of the GNU
General Public License version 2 (GPL2) as published by the Free Software
Foundation and appearing in the file GPL2.TXT included in the packaging of
this file. Please note that GPL2 Section 2 requires that all works based
** on this software must also be made publicly available under the terms of**
** the GPL2 ("Copyleft").**
** Contact information**
** Kristian Lauszus, TKJ Electronics**
** Web : http://www.tkjelectronics.com**
** e-mail : kristianl@tkjelectronics.com**
__ /__
#include <Wire.h>
#include <Kalman.h> // Source: GitHub - TKJElectronics/KalmanFilter: This is a Kalman filter used to calculate the angle, rate and bias from from the input of an accelerometer/magnetometer and a gyroscope.
#include <MPU6050.h>
#define RESTRICT_PITCH // Comment out to restrict roll to ±90deg instead - please read: http://www.freescale.com/files/sensors/doc/app_note/AN3461.pdf
MPU6050 mpu;
Kalman kalmanX; // Create the Kalman instances
Kalman kalmanY;
Kalman kalmanZ;
float yaw = 0;
__/ IMU Data /__
double accX, accY, accZ;
double gyroX, gyroY, gyroZ;
int16_t tempRaw;
double c;
double gyroXangle, gyroYangle,gyroZangle; // Angle calculate using the gyro only
double compAngleX, compAngleY,compAngleZ=180; // Calculated angle using a complementary filter
double kalAngleX, kalAngleY,kalAngleZ; // Calculated angle using a Kalman filter
uint32_t timer;
uint8_t i2cData[14]; // Buffer for I2C data
// TODO: Make calibration routine
** // mpu.calibrateGyro();*
** // mpu.setThreshold(1);**
** Serial.begin(115200);**
** Wire.begin();**
#if ARDUINO >= 157
** Wire.setClock(400000UL); // Set I2C frequency to 400kHz**
#else
** TWBR = ((F_CPU / 400000UL) - 16) / 2; // Set I2C frequency to 400kHz**
#endif
** i2cData[0] = 7; // Set the sample rate to 1000Hz - 8kHz/(7+1) = 1000Hz**
** i2cData[1] = 0x00; // Disable FSYNC and set 260 Hz Acc filtering, 256 Hz Gyro filtering, 8 KHz sampling**
** i2cData[2] = 0x00; // Set Gyro Full Scale Range to ±250deg/s**
** i2cData[3] = 0x00; // Set Accelerometer Full Scale Range to ±2g**
** while (i2cWrite(0x19, i2cData, 4, false)); // Write to all four registers at once**
** while (i2cWrite(0x6B, 0x01, true)); // PLL with X axis gyroscope reference and disable sleep mode**
** while (i2cRead(0x75, i2cData, 1));**
** if (i2cData[0] != 0x68) { // Read "WHO_AM_I" register**
** Serial.print(F("Error reading sensor"));**
** while (1);**
** delay(100); // Wait for sensor to stabilize**
__ /* Set kalman and gyro starting angle /__
** while (i2cRead(0x3B, i2cData, 6));*
** accX = (int16_t)((i2cData[0] << 8) | i2cData[1]);**
** accY = (int16_t)((i2cData[2] << 8) | i2cData[3]);**
** accZ = (int16_t)((i2cData[4] << 8) | i2cData[5]);**
** // Source: http://www.freescale.com/files/sensors/doc/app_note/AN3461.pdf eq. 25 and eq. 26**
** // atan2 outputs the value of -π to π (radians) - see atan2 - Wikipedia**
** // It is then converted from radians to degrees**
#ifdef RESTRICT_PITCH // Eq. 25 and 26
double roll = atan2(accY, accZ) * RAD_TO_DEG;
double pitch = atan(-accX / sqrt(accY * accY + accZ * accZ)) * RAD_TO_DEG;
#else // Eq. 28 and 29
double roll = atan(accY / sqrt(accX * accX + accZ * accZ)) * RAD_TO_DEG;
double pitch = atan2(-accX, accZ) * RAD_TO_DEG;
#endif
yaw = gyroZ RAD_TO_DEG;
** kalmanX.setAngle(roll); // Set starting angle*
** kalmanY.setAngle(pitch);**
** kalmanZ.setAngle(yaw);**
** gyroXangle = roll;**
** gyroYangle = pitch;**
** compAngleX = roll;**
** compAngleY = pitch;**
** gyroZangle = yaw;**
** timer = micros();**
__ /* Update all the values /__
** while (i2cRead(0x3B, i2cData, 14));*
** tempRaw = (int16_t)((i2cData[6] << 8) | i2cData[7]);**
** gyroX = (int16_t)((i2cData[8] << 8) | i2cData[9]);**
** gyroY = (int16_t)((i2cData[10] << 8) | i2cData[11]);**
** gyroZ = (int16_t)((i2cData[12] << 8) | i2cData[13]);;**
** double dt = (double)(micros() - timer) / 1000000; // Calculate delta time**
#endif
** double gyroXrate = gyroX / 131.0; // Convert to deg/s**
** double gyroYrate = gyroY / 131.0; // Convert to deg/s**
** double gyroZrate = -(double)gyroZ /131.0;**
** // This fixes the transition problem when the accelerometer angle jumps between -180 and 180 degrees**
** if ((roll < -90 && kalAngleX > 90) || (roll > 90 && kalAngleX < -90)) {**
** kalmanX.setAngle(roll);**
** kalAngleX = roll;**
** } else**
** kalAngleX = kalmanX.getAngle(roll, gyroXrate, dt); // Calculate the angle using a Kalman filter**
** if (abs(kalAngleX) > 90)**
** gyroYrate = -gyroYrate; // Invert rate, so it fits the restriced accelerometer reading**
** kalAngleY = kalmanY.getAngle(pitch, gyroYrate, dt);**
#else
** if ((pitch < -90 && kalAngleY > 90) || (pitch > 90 && kalAngleY < -90)) {**
** kalAngleY = pitch;**
** } else**
** kalAngleY = kalmanY.getAngle(pitch, gyroYrate, dt); // Calculate the angle using a Kalman filter**
** if (abs(kalAngleY) > 90)**
** gyroXrate = -gyroXrate; // Invert rate, so it fits the restriced accelerometer reading**
#endif
__ gyroXangle += gyroXrate * dt; // Calculate gyro angle without any filter__
__ gyroYangle += gyroYrate * dt;__
__ gyroZangle += gyroZrate * dt;__
__ //gyroXangle += kalmanX.getRate() * dt; // Calculate gyro angle using the unbiased rate__
__ //gyroYangle += kalmanY.getRate() * dt;__
__ compAngleX = 0.93 * (compAngleX + gyroXrate * dt) + 0.07 * roll; // Calculate the angle using a Complimentary filter__
__ compAngleY = 0.93 * (compAngleY + gyroYrate * dt) + 0.07 * pitch;__
__ compAngleZ = 0.93 * (compAngleZ + gyroZrate * dt) + (0.07 * gyroZangle);__
** kalAngleZ = kalmanZ.getAngle(gyroZangle,gyroZrate, dt);**
** // Reset the gyro angle when it has drifted too much**
** if (gyroXangle < -180 || gyroXangle > 180)**
** gyroXangle = kalAngleX;**
** if (gyroYangle < -180 || gyroYangle > 180)**
** gyroYangle = kalAngleY;**
** if(gyroZangle < -180 || gyroZangle >180)**
** gyroZangle = kalAngleZ;**
__ /* Print Data /__
__/#if 0 // Set to 1 to activate__
** Serial.print(accX); Serial.print("\t");**
** Serial.print(accY); Serial.print("\t");**
** Serial.print(accZ); Serial.print("\t");**
// Serial.print(gyroX); Serial.print("\t");
// Serial.print(gyroY); Serial.print("\t");
// Serial.print(gyroZrate); Serial.print("\t");
// Serial.print("\t");
/*#endif
** Serial.print(roll); Serial.print("\t");**
** Serial.print(gyroXangle); Serial.print("\t");**
** Serial.print(compAngleX); Serial.print("\t");**
** Serial.print(kalAngleX); Serial.print("\t");**
** Serial.print("\t");**
** Serial.print(pitch); Serial.print("\t");**
** Serial.print(gyroYangle); Serial.print("\t");**
** Serial.print(compAngleY); Serial.print("\t");**
** Serial.print(kalAngleY); Serial.print("\t");**
Serial.print(c); Serial.print("\t");
//#if 0 // Set to 1 to print the temperature
/* double temperature = (double)tempRaw / 340.0 + 36.53;
** Serial.print(temperature); Serial.print("\t");**
#endif
** Serial.print("\r\n");**
** delay(2);**
