WLRM
1
I am trying to find offset for acceleration readings from MPU6050.
Everthing was fine when I try to print one axis only.
Serial.println(Acc_X());
//Serial.print(",");
//Serial.print(Acc_Y());
//Serial.println(Acc_Z());
8.02
5.02
-5.98
3.02
but when I try to print two axis at the same time, the result are different.
Serial.print(Acc_X());
Serial.print(",");
Serial.println(Acc_Y());
-118.32,112.86
-125.32,111.86
-125.32,115.86
-119.32,105.86
Why is that? All I did was uncomment the following two line and the result had changed...
Here is the code
Test1.2.ino (4.64 KB)
#include "Wire.h"
#include "Math.h"
#define AccelerationOnly
//#define AngularVelocityOnly
//Calibration Times
int T = 50;
float AcXOffSet = 0, AcYOffSet = 0, AcZOffSet = 0,
GyXOffSet = 0, GyYOffSet = 0, GyZOffSet = 0;
Wire.begin();
MPU6050 Setup
//Set acceleration rate
Wire.beginTransmission(0x68);
Wire.write(0x1C);
Wire.requestFrom(0x68, 1, true);
unsigned char acc_conf = Wire.read();
//acc_conf = ((acc_conf & 0xE7) | (f << 3));
//acc_conf = ((acc_conf & 0xE7) | (0 << 3));
//acc_conf = ((acc_conf & 0xE7) | (1 << 3));
//acc_conf = ((acc_conf & 0xE7) | (2 << 3));
acc_conf = ((acc_conf & 0xE7) | (3 << 3));
Wire.write(acc_conf);
Wire.endTransmission(true);
//Set angular velocity rate
Wire.write(0x1B);
unsigned char gyr_conf = Wire.read();
//gyr_conf = ((gyr_conf & 0xE7) | (f << 3));
//gyr_conf = ((gyr_conf & 0xE7) | (0 << 3));
//gyr_conf = ((gyr_conf & 0xE7) | (1 << 3));
gyr_conf = ((gyr_conf & 0xE7) | (2 << 3));
//gyr_conf = ((gyr_conf & 0xE7) | (3 << 3));
Wire.write(gyr_conf);
//Calibration
calibrateAcc();
//calibrateGyr();
//Acceleration only
#ifdef AccelerationOnly
Serial.println("Acc_X Acc_Y Acc_Z");
#endif
//Angular Velocity only
#ifdef AngularVelocityOnly
Serial.println("Gyr_X Gyr_Y Gyr_Z");
#endif
//Write Data
Serial.print(",");
Serial.print(",");
#endif
Serial.print(Gyr_X);
Serial.print(",");
Serial.print(Gyr_Y);
Serial.print(",");
Serial.println(Gyr_Z);
#endif
//Read Acceleration on X axis
float Acc_X()
Wire.write(0x3B);
Wire.requestFrom(0x68, 2, true);
//return Wire.read() << 8 | Wire.read();
return ((Wire.read() << 8 | Wire.read()) - AcXOffSet);
//return ((16 * 9.8) * (Wire.read() << 8 | Wire.read()) / 32768);
//return (16 * 9.8 * ((Wire.read() << 8 | Wire.read()) - AcXOffSet) / 32768);
//Read Acceleration on Y axis
float Acc_Y()
Wire.write(0x3D);
return ((Wire.read() << 8 | Wire.read()) - AcYOffSet);
//return (16 * 9.8 * ((Wire.read() << 8 | Wire.read()) - AcYOffSet) / 32768);
//Read Acceleration on Z axis
float Acc_Z()
Wire.write(0x3F);
return ((Wire.read() << 8 | Wire.read()) - AcZOffSet);
//return (16 * 9.8 * ((Wire.read() << 8 | Wire.read()) - AcZOffSet) / 32768);
//Read Angular velocity on X axis
float Gyr_X()
Wire.write(0x43);
return (1000 * ((Wire.read() << 8 | Wire.read()) - GyXOffSet) / 32768);
//Read Angular velocity on Y axis
float Gyr_Y()
Wire.write(0x45);
return (1000 * ((Wire.read() << 8 | Wire.read()) - GyYOffSet) / 32768);
//Read Angular velocity on Z axis
float Gyr_Z()
Wire.write(0x47);
return (1000 * ((Wire.read() << 8 | Wire.read()) - GyZOffSet) / 32768);
void calibrateAcc()
float X = 0;
Acc_X();
for (int i = 0; i < T; i++)
X += Acc_X();
delay(10);
AcXOffSet = X / T;
float Y = 0;
Acc_Y();
Y += Acc_Y();
delay(10);
AcYOffSet = Y / T;
float Z = 0;
Acc_Z();
Z += Acc_Z();
delay(10);
AcZOffSet = Z / T;
void calibrateGyr()
//Calibrate Gyr X
float X = 0;
X += Gyr_X();
delay(10);
GyXOffSet = X / T;
//Calibrate Gyr Y
float Y = 0;
Y += Gyr_Y();
delay(10);
GyYOffSet = Y / T;
//Calibrate Gyr Z
float Z = 0;
Z += Gyr_Z();
delay(10);
GyZOffSet = Z / T;
WLRM
3
Sorry, first time posting. How do I move it to the forum?
