Mpu6050 pattern converting to code - newbie
#include <EEPROM.h>
#include <FastLED.h>
// I2Cdev and MPU6050 must be installed as libraries
#include "I2Cdev.h"
#include "MPU6050.h"
#include "Wire.h"
#define NUM_STRIPS 2
#define NUM_LEDS_PER_STRIP 15
#define BRIGHTNESS  100
#define LED_TYPE    WS2811
CRGB leds[NUM_STRIPS][NUM_LEDS_PER_STRIP];
unsigned long actTime = 0;
unsigned long remTime = 0;
const unsigned long period = 400;
bool is_red = true;
int IF_d = 0; // dito nareregister kung naka on na ba o hindi
#define btnCalPin   4
#define btnBTOffPin 6
#define btnBTOffSig 5
#define buzPin      10
int sampleTimes = 1000;   //Amount of readings used to average, make it higher to get more precision but sketch will be slower  (default:1000)
int sampleOffset = 100;
int acel_deadzone = 8;   //Acelerometer error allowed, make it lower to get more precision, but sketch may not converge  (default:8)
int giro_deadzone = 1;   //Giro error allowed, make it lower to get more precision, but sketch may not converge  (default:1)
const long btSpeed = 38400;
int x =0;
MPU6050 accelgyro(0x68); // <-- use for AD0 high
typedef struct gyroval {
  int16_t ax;
  int16_t ay;
  int16_t az;
  int16_t gx;
  int16_t gy;
  int16_t gz;
  int8_t  btoff;
} GyroVal;
GyroVal gv;
int16_t gyValUD, gyValLR;
const int8_t OFF_d   = 0;
const int8_t LEFT_d  = 1;
const int8_t RIGHT_d = 2;
const int8_t LAST_d = 3;
const int16_t MAX_d1     = 10000;
const int16_t MAX_d2    = -10000;
const int16_t MIN_d        = -6000; //15000 default
const int16_t MAX_d        = 6000;
const int16_t MAXINTTIME_d    = 1600; //dito yung whole time ng na magaaccept ng 2x swings
const int16_t MAXSIGTIME_d = 400; //ito yung time na 1 swing lang
int8_t ledState_d = OFF_d;
int8_t  ledState = OFF_d;
int8_t  oledState = OFF_d;
int8_t  led = OFF_d;
int8_t prevSignalLR = OFF_d;
int8_t stateLR  = 0;
int8_t numSigLR = 0;
int8_t signalUD = OFF_d;
int8_t numSigUD  = 0;
unsigned long startTime = millis();
unsigned long currTime = startTime;
long lastTime = 0;
unsigned long intTime;
unsigned long sigTime;
int addr = 0;
int btnCalState = 0;
int8_t blueToothOff = 0;
int XAxGForce;
  FastLED.setMaxPowerInVoltsAndMilliamps(5,1000);
      // tell FastLED there's 60 NEOPIXEL leds on pin 10
  FastLED.addLeds<NEOPIXEL, 8>(leds[0], NUM_LEDS_PER_STRIP);
  // tell FastLED there's 60 NEOPIXEL leds on pin 11
  FastLED.addLeds<NEOPIXEL, 7>(leds[1], NUM_LEDS_PER_STRIP);
      FastLED.setBrightness(BRIGHTNESS);
  Wire.begin();
  // COMMENT NEXT LINE IF YOU ARE USING ARDUINO DUE
  TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz). Leonardo measured 250kHz.
  Serial.begin(38400);
  //initialize device
  accelgyro.initialize();
  Serial.println("\nMPU6050 Connection...");
  delay(2000);
  if (accelgyro.testConnection()) {
    Serial.println("MPU6050 connection successful");
  else {
    Serial.println("MPU6050 connection failed");
    while (1) ;
  EEPROM.get(0, gv);
  if (gv.ax != 65535) accelgyro.setXAccelOffset(gv.ax);
  else accelgyro.setXAccelOffset(-10);
  if (gv.ay != 65535) accelgyro.setYAccelOffset(gv.ay);
  else accelgyro.setYAccelOffset(-1);
  if (gv.az != 65535) accelgyro.setZAccelOffset(gv.az);
  else accelgyro.setZAccelOffset(16385);
  if (gv.gx != 65535) accelgyro.setXGyroOffset(gv.gx);
  else accelgyro.setXGyroOffset(0);
  if (gv.gy != 65535) accelgyro.setYGyroOffset(gv.gy);
  else accelgyro.setYGyroOffset(0);
  if (gv.gz != 65535) accelgyro.setZGyroOffset(gv.gz);
  else accelgyro.setZGyroOffset(1);
  if (gv.btoff != 255) {
    digitalWrite(btnBTOffSig, HIGH);
    blueToothOff = 1;
  else {
    digitalWrite(btnBTOffSig, LOW);
    blueToothOff = 0;
    Serial1.begin(btSpeed);
  Serial.println("Start reading sensor...");
   actTime = millis();
  currTime = millis();
  if (btnCalState == HIGH) {
    tone(buzPin, 2500);
    delay (500);
    noTone(buzPin);
    delay (200);
    tone(buzPin, 2500);
    delay (500);
    noTone(buzPin);
    delay (2000);
    calibration();
    for (int i = 0; i < 3; i++) {
      tone(buzPin, 2500);
      delay (200);
      noTone(buzPin);
      delay (200);
    tone(buzPin, 2500);
    delay (500);
    noTone(buzPin);
    delay(5000);
  accelgyro.getMotion6(&gv.ax, &gv.ay, &gv.az, &gv.gx, &gv.gy, &gv.gz);
  //Serial.print(gv.ax, DEC);
  //Serial.print("\t");
 Serial.print(currTime, DEC);
  Serial.print("\t");
  Serial.print(gv.gy, DEC);
 Serial.print("\t");
  Serial.println(gv.gz, DEC);
  Serial.print("\t");
  if (blueToothOff == 0) {
    //Serial1.print(gv.ax, DEC);
   // Serial1.print("\t");
    //Serial1.print(currTime, DEC);
    //Serial1.print("\t");
   // Serial1.print(gv.gx, DEC);
    Serial1.print(gv.gy, DEC);
    Serial1.print(gv.gz, DEC);
    Serial1.println("#");
    Serial1.println(XAxGForce, DEC);
  gyValUD  = gv.gy;
  gyValLR = gv.gz;
  if( gyValLR >= MAX_d ){
        if( gyValLR <= MIN_d ){
                  ledState = LEFT_d;
                  osignal();
    else if( gyValLR <= MIN_d ){
      ledState = RIGHT_d;
      osignal();
Hi Guys, I need your help to approach this type of coding. Im using a mpu6050 and using the gyroscope value, I wanted to create a code that will read this pattern in the plotter, please see image above. First If the program first detected -6000 then 6000 then -6000 then 6000 this will on the left led. And if the detected first the 6000 then -6000 then 6000 then -6000 it will on the right led.
Thank you for your suggestions
so you have alternating values (which seems weird from a MPU)
+6000…-6000…+6000…-6000…+6000…-6000…+6000…-6000…
Your need seems flawed as it depends when you start measuring with your arduino. if you started measuring at a +6000 you’ll have the right led on, but if you booted up your arduino at -6000 you’ll have the left LED on… but in both cases the signal was really the same
what’s the real need?
