Hello all, I'm starting with Arduino projects and i'm currently facing a problem that maybe someone here can help me. My project is small car that has a self balancing platform over it. The platform rotation is provided by a servo motor. And over this platform a MPU6050 sensor is placed to get its angle. This car will walk through an irregular surface and the platform should be always parallel (90 degress) with this surface.
The problem starts when the code operate my current read with the error obtained from the setpoint.
My code is bellow and the problem is written in red:
#include<Wire.h>
#include "Servo.h"
//Start I2C address for MPU6050
const int MPU=0x68;
//Variables to storage sensor data
int AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
int degA = 0, degP = 0;
int servoOutputPercentage = 0, servoOutputDegrees = 0;
//Control variables
float setPoint = 50; //50% means that my platform is 90 degress
float error = 0;
//DC car motor control
int TransistorPin = 3;
int PotencPin = A0;
int ReadPot = 0;
int ValuePWM = 0;
Servo myservo;
Wire.begin();
Wire.beginTransmission(MPU);
Wire.write(0x6B);
//Starting MPU-6050
Wire.write(0);
Wire.endTransmission(true);
//Set platform to start position
myservo.attach(9);
myservo.write(90);
delay(3000);
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
//Requesting data from sensor
Wire.requestFrom(MPU,14,true);
//Reading values from MPU
AcX=Wire.read()<<8|Wire.read(); //0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8|Wire.read(); //0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ=Wire.read()<<8|Wire.read(); //0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp=Wire.read()<<8|Wire.read(); //0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyX=Wire.read()<<8|Wire.read(); //0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY=Wire.read()<<8|Wire.read(); //0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ=Wire.read()<<8|Wire.read(); //0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
//Limiting the values from sensor from 65 to 115 degrees
if(AcY<=-4500) AcY=-4500;
if(AcY>=5000) AcY=5000;
//Converting AcY to angles and percentage
degA = map(AcY, -17000, 17000, 0, 179);
degP = map(AcY, -4500, 5000, 0, 100);
error = setPoint - degP; //comparing my setpoint with current read from MPU in percentage
servoOutputPercentage=degP + error; [b][color=red]Here is the problem, my variable servoOutputPercentage stays always locked in 90[/color][/b]
servoOutputDegrees=map(servoOutputPercentage, 0, 100, 65, 115);
//Servo output
myservo.write(servoOutputDegrees);
//DC motor control
ReadPot = analogRead(PotencPin);
ValuePWM = map(ReadPot, 0, 1023, 0, 255);
analogWrite(TransistorPin, ValorPWM);
delay(100);
Could you please help me in this case?
Thanks in advance.
