Hi Guys,
I am a bit stuck here, I need a method of voiding the loop ideally through a switch. Currently the circuit i have running does not integrate this as i am currently testing and calibrating the code.
The problem is that the motor loops between on and off status rapidly as the gx changes due to the second if statements function. I am looking for a way to use the gx to turn off the motor until a reset occurs (Switch flipped on and off again) So am hoping there is a simple function i have missed?
Code and Diagram attatched
#include <Wire.h>
#include<I2Cdev.h>
#include<MPU6050.h>
MPU6050 mpu;
int16_t ax, ay, az;
int16_t gx, gy, gz;
#define pin1 3
#define pin2 5
void setup(){
Serial.println("Initialize MPU");
mpu.initialize();
//Serial.println(mpu.testConnection() ? "Connected" : "Connection failed"); pinMode(pin1,OUTPUT);
pinMode(pin2,OUTPUT);
void loop(){
mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
ax = map(ax, -17000, 17000, -1500, 1500);
//Serial.println(ax);
if(gx<-200){
if(gx>-1000){
Serial.println("go");
analogWrite(pin1, 255);
else{
Serial.println("Stop");
analogWrite(pin1, 0);
delay(100);
