I’ve managed to fuse the data from MPU’s Acc/Gyro and QMC Magnetometer using Madgwick filter. Basicly what the code does in main loop is gathering values from Acc, Gyro and Mag. Then making data fusion with MadgwickAHRS, calculating yaw, pitch, roll angles and sending them through serial port with 2000000 baud rate. I’m using “Visualiser” code for Processing from MadgwickAHRS library directory to see the results.
As You may now, to get the rotation angle from gyro we need to integrate gyro readings. And I think that is my problem. For now I measured the void loop() cycle whith micros() function and it takes ~8621 microseconds. So the loop frequency is about 128Hz. So I set the filter frequency at 128Hz ( " filter.begin(128); ") and I get very accurate results. But I don’t think that is the correct solution. Because if I would change the baud rate or add a few lines of code, the loop frequency would change.
I tried to execute the filter.update() function, for example, every 10000 microseconds and set the filter frequency to 100Hz, but that’s not working the way i expected.
Any tips how to make this code more reliable?
btw. the board I’m using is Arduino UNO r.3
#include <MadgwickAHRS.h>
#include<Wire.h>
const int MPU_addr = 0x68, QMC_addr = 0x0D; // I2C address of the MPU-6050 and QMC
float AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ, MaX, MaY, MaZ ;
long GyX_cal = 0, GyY_cal = 0, GyZ_cal = 0, AcX_cal = 0, AcY_cal = 0;
unsigned long loop_timer=0, interval = 0;
Madgwick filter;
float calibrated_values[3];
float uncalibrated_values[3];
float roll = 0, pitch = 0, heading = 0;
Wire.begin();
Serial.begin(2000000);
MPU_init();
QMC_init();
Gyro_cal();
filter.begin(128);
loop_timer = micros();
// MPU reading values
MPU_read();
// Gyroscope offset / calibration
GyX -= GyX_cal;
GyY -= GyY_cal;
GyZ -= GyZ_cal;
// Accelerometer offset / calibration
AcX -= AcX_cal;
AcY -= AcY_cal;
AcZ -= 0;
GyX *=0.015267;
GyY *=0.015267;
GyZ *=0.015267;
QMC_read();
uncalibrated_values[0]= MaX;
uncalibrated_values[1]= MaY;
uncalibrated_values[2]= MaZ;
transformation(uncalibrated_values);
MaX = calibrated_values[0] ;
MaY = calibrated_values[1] ;
MaZ = calibrated_values[2] ;
filter.update(GyX, GyY, GyZ, AcX, AcY, AcZ, MaX, MaY, MaZ);
roll = filter.getRoll();
pitch = filter.getPitch();
heading = filter.getYaw();
Serial.print("Orientation: ");
Serial.print(heading);
Serial.print(" ");
Serial.print(pitch);
Serial.print(" ");
Serial.println(roll);
// Serial.println(micros()-loop_timer);
void MPU_init()
//Activate the MPU-6050
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B);
Wire.write(0x00);
Wire.endTransmission(true);
//Configure the accelerometer (+/-8g)
Wire.write(0x1C);
Wire.write(0x08);
//Configure the gyro (500dps full scale)
Wire.write(0x1B);
Wire.write(0x08);
void QMC_init()
Wire.beginTransmission(QMC_addr); //start talking
Wire.write(0x0B); // Tell the HMC5883 to Continuously Measure
Wire.write(0x01); // value
Wire.endTransmission();
Wire.write(0x09); // Tell the HMC5883 to Continuously Measure
Wire.write(0x1D); // value
void MPU_read()
{ //Subroutine for reading the raw gyro and accelerometer data
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr, 14, true); // request a total of 14 registers
AcX = Wire.read() << 8 | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY = Wire.read() << 8 | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ = Wire.read() << 8 | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp = Wire.read() << 8 | Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyX = Wire.read() << 8 | Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY = Wire.read() << 8 | Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ = Wire.read() << 8 | Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
void QMC_read()
Wire.write(0x00);
Wire.requestFrom(QMC_addr, 14);
while (Wire.available() < 3);
MaX = (float)(Wire.read() | Wire.read() <<8);
MaY = (float)(Wire.read() | Wire.read() << 8);
MaZ = (float)(Wire.read() | Wire.read() << 8);
void Gyro_cal()
Serial.println("Wait. Calibrating IMU.");
for (int cal_int = 0; cal_int < 2000 ; cal_int ++) //Run this code 2000 times
MPU_read();
GyX_cal += GyX;
GyY_cal += GyY;
GyZ_cal += GyZ;
AcX_cal += AcX;
AcY_cal += AcY;
delay(3);
GyX_cal /= 2000;
GyY_cal /= 2000;
GyZ_cal /= 2000;
AcX_cal /= 2000;
AcY_cal /= 2000;
Serial.println("Calibration done!");
void transformation(float uncalibrated_values[3])
double calibration_matrix[3][3] =
{1.169, -0.007, 0.147},
{-0.041, 1.167, 0.085},
{-0.028, -0.001, 1.398}
double bias[3] =
-563.145,
-80.378,
-31.331
//calculation
for (int i=0; i<3; ++i) uncalibrated_values[i] = uncalibrated_values[i] - bias[i];
float result[3] = {0, 0, 0};
for (int j=0; j<3; ++j)
result[i] += calibration_matrix[i][j] * uncalibrated_values[j];
for (int i=0; i<3; ++i) calibrated_values[i] = result[i];
