MPU6050 raw data file not compiling.
I am using NODEMCUv 1.0
and trying to compile the code by the GitHub - jrowberg/i2cdevlib: I2C device library collection for AVR/Arduino or other C++-based MCUs raw file but not able to since two days
getting the following same error-
with verbose off-
Arduino: 1.8.5 (Windows 7), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 4M (3M SPIFFS), v2 Lower Memory, Serial, None, Only Sketch, 115200"
C:\Users\sound\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp: In static member function 'static int8_t I2Cdev::readBytes(uint8_t, uint8_t, uint8_t, uint8_t*, uint16_t)':
C:\Users\sound\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp:276:75: error: no matching function for call to 'min(uint8_t&, int)'
             for (uint8_t k = 0; k < length; k += min(length, BUFFER_LENGTH)) {
C:\Users\sound\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp:276:75: note: candidates are:
In file included from c:\users\sound\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\algorithm:62:0,
                 from C:\Users\sound\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266/Arduino.h:254,
                 from C:\Users\sound\Documents\Arduino\libraries\I2Cdev\I2Cdev.h:80,
                 from C:\Users\sound\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp:46:
c:\users\sound\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4226:5: note: template<class _Tp, class _Compare> _Tp std::min(std::initializer_list<_Tp>, _Compare)
     min(initializer_list<_Tp> __l, _Compare __comp)
c:\users\sound\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4226:5: note:   template argument deduction/substitution failed:
C:\Users\sound\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp:276:75: note:   mismatched types 'std::initializer_list<_Tp>' and 'unsigned char'
c:\users\sound\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4221:5: note: template<class _Tp> _Tp std::min(std::initializer_list<_Tp>)
     min(initializer_list<_Tp> __l)
c:\users\sound\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4221:5: note:   template argument deduction/substitution failed:
In file included from c:\users\sound\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\algorithm:61:0,
c:\users\sound\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:239:5: note: template<class _Tp, class _Compare> const _Tp& std::min(const _Tp&, const _Tp&, _Compare)
     min(const _Tp& __a, const _Tp& __b, _Compare __comp)
c:\users\sound\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:239:5: note:   template argument deduction/substitution failed:
C:\Users\sound\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp:276:75: note:   deduced conflicting types for parameter 'const _Tp' ('unsigned char' and 'int')
c:\users\sound\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:193:5: note: template<class _Tp> const _Tp& std::min(const _Tp&, const _Tp&)
     min(const _Tp& __a, const _Tp& __b)
c:\users\sound\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:193:5: note:   template argument deduction/substitution failed:
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
option enabled in File -> Preferences.
please help me out with this problem
error with verbose on.txt (23.2 KB)
What have you done for two days? Just trying to compile your code over and over, when the problem is in the library, is pointless.
min() wants both arguments to be the same type - either byte or int, not one of each.
But, since you didn't post your code or a link to the library, you are on your own in determining what changes to make to the library.
