MPU6050 reads only zero in all values
Hi, All. I been using MPU6050 accelerometers (board GY-521) for a while, the board is solder attached to a Wemos D1 Mini boards without a hitch. But recently I bought a large batch (500 pieces) and now the sensors reads zeros on all its values.
At this moment i randomly selected 25 pieces out of 500 and all of them give the same result.
I should point out that the very same code and wemos board works fine with the MPU6050 i already had; and in the 25 tested there is good serial communication. (no serial errors at all, but just zeros when the accel, gyro and temp reads)
Is there a possibility that there are differences on some chips (like hardware version)?
The MPU6050 was officially discontinued many years ago, and what you get these days is almost certainly a clone, counterfeit or just plain fake. Send them back.
What library are you using for these sensors? Have you tried any of the test sketches that were installed with the library?
If those sketches also give zero readings, I agree with @jremington
I polled the MPU registers directly by using only the wire.h library and also tried with the Adafruit's library. In both cases the program works with the sensors I originally had; and both programs failed with the new batch.
Try to get your money back and move on.
It is the first time that I hear about a completely bogus MPU-6050. Most are counterfeits. Perhaps it is something else. Can you try to read the "WHO_AM_I" at register address 0x75 ?
It should be 0x68 for a MPU-6050.
What is your project about ?
Will there be many wires to many sensors ? The I2C was not designed to go through a wire.
That sounds pretty conclusive. Sorry.
Yes, I did: the Who Am I register shows a 104 (68 hex).
It's the only sensor connected to the wemos board, and the distance between both are less than 3 millimeters.
Then it is not an other sensor but a counterfeit MPU-6050.
This is the shortest code: https://playground.arduino.cc/Main/MPU-6050/#short
If you want, you can try that for a final test.
