I've tried different libraries and code however I've been reading this values for the sensor:
AcX = -7728 | AcY = 32528 | AcZ = 9014 | Tmp = 26.24 | GyX = -296 | GyY = 116 | GyZ = -69
AcX = -7738 | AcY = 32518 | AcZ = 9030 | Tmp = 26.24 | GyX = -296 | GyY = 119 | GyZ = -68
AcX = -7718 | AcY = 32502 | AcZ = 9016 | Tmp = 26.23 | GyX = -298 | GyY = 117 | GyZ = -69
AcX = -7720 | AcY = 32492 | AcZ = 9034 | Tmp = 26.24 | GyX = -297 | GyY = 120 | GyZ = -68
AcX = -7706 | AcY = 32498 | AcZ = 9016 | Tmp = 26.25 | GyX = -300 | GyY = 115 | GyZ = -67
AcX = -7716 | AcY = 32498 | AcZ = 9042 | Tmp = 26.23 | GyX = -296 | GyY = 116 | GyZ = -73
AcX = -7716 | AcY = 32500 | AcZ = 9034 | Tmp = 26.24 | GyX = -295 | GyY = 117 | GyZ = -68
AcX = -7706 | AcY = 32528 | AcZ = 9020 | Tmp = 26.24 | GyX = -296 | GyY = 114 | GyZ = -68
AcX = -7722 | AcY = 32510 | AcZ = 9062 | Tmp = 26.23 | GyX = -297 | GyY = 118 | GyZ = -67
AcX = -7708 | AcY = 32482 | AcZ = 9004 | Tmp = 26.24 | GyX = -296 | GyY = 114 | GyZ = -64
Those last samples were taken using the short example sketch availabe at playground.arduino
// MPU-6050 Short Example Sketch
// By Arduino User JohnChi
// August 17, 2014
// Public Domain
#include<Wire.h>
const int MPU=0x68; // I2C address of the MPU-6050
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
void setup(){
Wire.begin();
Wire.beginTransmission(MPU);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
void loop(){
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU,14,true); // request a total of 14 registers
AcX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp=Wire.read()<<8|Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
Serial.print("AcX = "); Serial.print(AcX);
Serial.print(" | AcY = "); Serial.print(AcY);
Serial.print(" | AcZ = "); Serial.print(AcZ);
Serial.print(" | Tmp = "); Serial.print(Tmp/340.00+36.53); //equation for temperature in degrees C from datasheet
Serial.print(" | GyX = "); Serial.print(GyX);
Serial.print(" | GyY = "); Serial.print(GyY);
Serial.print(" | GyZ = "); Serial.println(GyZ);
delay(333);
Could the Y axis accelerometer be damaged?
