I have my mpu6050 wired to my Arduino Nano which is plugged into my laptop. It has worked perfectly fine in the past though very suddenly it has stopped functioning. The light on the board goes dim or off completely and I am no longer getting any accelerometer values.
More details I forgot to add: when uploading code the LED on the mpu6050 goes out, when the code is done uploading it turns back on but dims. there is a servomotor wired to the nano as well and with the MPU6050 not functioning that sketch won't even write to the servo.
I will take a SWAG and suggest you disconnect the servo before uploading your code. Posting a schematic not a frizzy picture would be a big help. Be sure to show all the connections even power and ground.
