MPU6050 using kalman filter and want to use yaw axis
hello everyone, I'm using kalman filter with mpu6050 and all the code have it's use only roll and pitch axis. but what i want to use in my project is yaw axis. but i don't know how to use yaw axis in kalman filter code. so please help me.
/* Copyright (C) 2012 Kristian Lauszus, TKJ Electronics. All rights reserved.
This software may be distributed and modified under the terms of the GNU
General Public License version 2 (GPL2) as published by the Free Software
Foundation and appearing in the file GPL2.TXT included in the packaging of
this file. Please note that GPL2 Section 2 requires that all works based
** on this software must also be made publicly available under the terms of**
** the GPL2 ("Copyleft").**
** Contact information**
** Kristian Lauszus, TKJ Electronics**
** Web : http://www.tkjelectronics.com**
** e-mail : kristianl@tkjelectronics.com**
__ /__
#include <Wire.h>
#include <Kalman.h> // Source: GitHub - TKJElectronics/KalmanFilter: This is a Kalman filter used to calculate the angle, rate and bias from from the input of an accelerometer/magnetometer and a gyroscope.
#include <MPU6050.h>
#define RESTRICT_PITCH // Comment out to restrict roll to ±90deg instead - please read: http://www.freescale.com/files/sensors/doc/app_note/AN3461.pdf
MPU6050 mpu;
Kalman kalmanX; // Create the Kalman instances
Kalman kalmanY;
Kalman kalmanZ;
float yaw = 0;
__/
IMU Data /__
double accX, accY, accZ;
double gyroX, gyroY, gyroZ;
int16_t tempRaw;
double c;
double gyroXangle, gyroYangle,gyroZangle; // Angle calculate using the gyro only
double compAngleX, compAngleY,compAngleZ=180; // Calculated angle using a complementary filter
double kalAngleX, kalAngleY,kalAngleZ; // Calculated angle using a Kalman filter
uint32_t timer;
uint8_t i2cData[14]; // Buffer for I2C data
// TODO: Make calibration routine
** // mpu.calibrateGyro();
** // mpu.setThreshold(1);**
** Serial.begin(115200);**
** Wire.begin();**
#if ARDUINO >= 157
** Wire.setClock(400000UL); // Set I2C frequency to 400kHz**
#else
** TWBR = ((F_CPU / 400000UL) - 16) / 2; // Set I2C frequency to 400kHz**
#endif
** i2cData[0] = 7; // Set the sample rate to 1000Hz - 8kHz/(7+1) = 1000Hz**
** i2cData[1] = 0x00; // Disable FSYNC and set 260 Hz Acc filtering, 256 Hz Gyro filtering, 8 KHz sampling**
** i2cData[2] = 0x00; // Set Gyro Full Scale Range to ±250deg/s**
** i2cData[3] = 0x00; // Set Accelerometer Full Scale Range to ±2g**
** while (i2cWrite(0x19, i2cData, 4, false)); // Write to all four registers at once**
** while (i2cWrite(0x6B, 0x01, true)); // PLL with X axis gyroscope reference and disable sleep mode**
** while (i2cRead(0x75, i2cData, 1));**
** if (i2cData[0] != 0x68) { // Read "WHO_AM_I" register**
** Serial.print(F("Error reading sensor"));**
** while (1);**
** delay(100); // Wait for sensor to stabilize**
__ /* Set kalman and gyro starting angle /__
** while (i2cRead(0x3B, i2cData, 6));
** accX = (int16_t)((i2cData[0] << 8) | i2cData[1]);**
** accY = (int16_t)((i2cData[2] << 8) | i2cData[3]);**
** accZ = (int16_t)((i2cData[4] << 8) | i2cData[5]);**
** // Source: http://www.freescale.com/files/sensors/doc/app_note/AN3461.pdf eq. 25 and eq. 26**
** // atan2 outputs the value of -π to π (radians) - see atan2 - Wikipedia**
** // It is then converted from radians to degrees**
#ifdef RESTRICT_PITCH // Eq. 25 and 26
double roll = atan2(accY, accZ) * RAD_TO_DEG;
double pitch = atan(-accX / sqrt(accY * accY + accZ * accZ)) * RAD_TO_DEG;
#else // Eq. 28 and 29
double roll = atan(accY / sqrt(accX * accX + accZ * accZ)) * RAD_TO_DEG;
double pitch = atan2(-accX, accZ) * RAD_TO_DEG;
#endif
yaw = gyroZ RAD_TO_DEG;
** kalmanX.setAngle(roll); // Set starting angle
** kalmanY.setAngle(pitch);**
** kalmanZ.setAngle(yaw);**
** gyroXangle = roll;**
** gyroYangle = pitch;**
** compAngleX = roll;**
** compAngleY = pitch;**
** gyroZangle = yaw;**
** timer = micros();**
__ /* Update all the values /__
** while (i2cRead(0x3B, i2cData, 14));
** tempRaw = (int16_t)((i2cData[6] << 8) | i2cData[7]);**
** gyroX = (int16_t)((i2cData[8] << 8) | i2cData[9]);**
** gyroY = (int16_t)((i2cData[10] << 8) | i2cData[11]);**
** gyroZ = (int16_t)((i2cData[12] << 8) | i2cData[13]);;**
** double dt = (double)(micros() - timer) / 1000000; // Calculate delta time**
#endif
** double gyroXrate = gyroX / 131.0; // Convert to deg/s**
** double gyroYrate = gyroY / 131.0; // Convert to deg/s**
** double gyroZrate = -(double)gyroZ /131.0;**
** // This fixes the transition problem when the accelerometer angle jumps between -180 and 180 degrees**
** if ((roll < -90 && kalAngleX > 90) || (roll > 90 && kalAngleX < -90)) {**
** kalmanX.setAngle(roll);**
** kalAngleX = roll;**
** } else**
** kalAngleX = kalmanX.getAngle(roll, gyroXrate, dt); // Calculate the angle using a Kalman filter**
** if (abs(kalAngleX) > 90)**
** gyroYrate = -gyroYrate; // Invert rate, so it fits the restriced accelerometer reading**
** kalAngleY = kalmanY.getAngle(pitch, gyroYrate, dt);**
#else
** if ((pitch < -90 && kalAngleY > 90) || (pitch > 90 && kalAngleY < -90)) {**
** kalAngleY = pitch;**
** } else**
** kalAngleY = kalmanY.getAngle(pitch, gyroYrate, dt); // Calculate the angle using a Kalman filter**
** if (abs(kalAngleY) > 90)**
** gyroXrate = -gyroXrate; // Invert rate, so it fits the restriced accelerometer reading**
#endif
__ gyroXangle += gyroXrate * dt; // Calculate gyro angle without any filter__
__ gyroYangle += gyroYrate * dt;__
__ gyroZangle += gyroZrate * dt;__
__ //gyroXangle += kalmanX.getRate() * dt; // Calculate gyro angle using the unbiased rate__
__ //gyroYangle += kalmanY.getRate() * dt;__
__ compAngleX = 0.93 * (compAngleX + gyroXrate * dt) + 0.07 * roll; // Calculate the angle using a Complimentary filter__
__ compAngleY = 0.93 * (compAngleY + gyroYrate * dt) + 0.07 * pitch;__
__ compAngleZ = 0.93 * (compAngleZ + gyroZrate * dt) + (0.07 * gyroZangle);__
** kalAngleZ = kalmanZ.getAngle(gyroZangle,gyroZrate, dt);**
** // Reset the gyro angle when it has drifted too much**
** if (gyroXangle < -180 || gyroXangle > 180)**
** gyroXangle = kalAngleX;**
** if (gyroYangle < -180 || gyroYangle > 180)**
** gyroYangle = kalAngleY;**
** if(gyroZangle < -180 || gyroZangle >180)**
** gyroZangle = kalAngleZ;**
__ /* Print Data /__
__/
#if 0 // Set to 1 to activate__
** Serial.print(accX); Serial.print("\t");**
** Serial.print(accY); Serial.print("\t");**
** Serial.print(accZ); Serial.print("\t");**
// Serial.print(gyroX); Serial.print("\t");
// Serial.print(gyroY); Serial.print("\t");
// Serial.print(gyroZrate); Serial.print("\t");
// Serial.print("\t");
/*#endif
** Serial.print(roll); Serial.print("\t");**
** Serial.print(gyroXangle); Serial.print("\t");**
** Serial.print(compAngleX); Serial.print("\t");**
** Serial.print(kalAngleX); Serial.print("\t");**
** Serial.print("\t");**
** Serial.print(pitch); Serial.print("\t");**
** Serial.print(gyroYangle); Serial.print("\t");**
** Serial.print(compAngleY); Serial.print("\t");**
** Serial.print(kalAngleY); Serial.print("\t");**
Serial.print(c); Serial.print("\t");
//#if 0 // Set to 1 to print the temperature
/* double temperature = (double)tempRaw / 340.0 + 36.53;
** Serial.print(temperature); Serial.print("\t");**
#endif
** Serial.print("\r\n");**
** delay(2);**
Please edit your post to add code tags, as described in the "How to use this forum" post.
The absolute value of yaw cannot be determined with the MPU-6050, because it has no North reference (magnetometer). You can get only a relative value of yaw by integrating the gyro output.
Don't waste your time with that code, it is not even a Kalman filter.
Use Jeff Rowberg's DMP library for the MPU-6050 instead.
