Hi
I'm looking at the little code snippet from this (many other projects also use similar code):
void loop(){
mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
ax = map(ax, -17000, 17000, -1500, 1500);
If my reading is correct, it's assuming the value of ax to be between -17000 and 17000. But isn't the value supposed to be 16-bit? If so, shouldn't the range be wider than -17000, 17000? Is the value capped?
Any thought appreciated.
Thanks
