I am building (just for the hell of it) what can be concidered a single arm of a 4 arm drone on a bread board just to learn. I have the motor, esc and everything working fine. The Uno is talking to the ESC and the motor / prop is responding as expected.
I glued a MPU6050 gyro to the board. When I open Serial Monitor in the IDE I can see the gyro respond correctly as I tilt the board: the gyro knows where the it (and the bread board) relative to the earth.
When I run the same program while the motor / prop are running I get wild numbers from the Gyro. I tried to isolate the gyro with its own power supply and still get wild numbers. I tried to isolate the gyro physically on small foam but still wild fluxuations only when the motor / prop run.
If I stop the motor / prop then the gyro responds normally. I I ever build a drone I will of course need a reliable gyro: so what am I doing wrong here?
Thank you!
