Hi
I would like to and am trying to use a 6DOF MPU6050 to create a basic hand mocap device for use inside unity.
I am reading the YAW PITCH and ROLL, all as standard from the library found here
The thing is, i didnt know what was what with the values, so i altered the arduino sketch from this
#ifdef OUTPUT_READABLE_YAWPITCHROLL
// display Euler angles in degrees
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
Serial.print("ypr\t");
Serial.print(ypr[0] * 180/M_PI);
Serial.print("\t");
Serial.print(ypr[1] * 180/M_PI);
Serial.print("\t");
Serial.println(ypr[2] * 180/M_PI);
#endif
to this
Serial.print("|X:");
Serial.print(ypr[0] * 360/M_PI);
Serial.print("|Y:");
Serial.print(ypr[1] * 360/M_PI);
Serial.print("|Z:");
Serial.print(ypr[2] * 360/M_PI);
Serial.println("|");
#endif
in my c# script for unity, i read these in a basic way, though i know it isnt the most efficient, like this
Data = SP.ReadLine ();
if ( Data == "Initializing I2C devices...")
SP.WriteLine ("0");
//SP.DiscardInBuffer ();
//SP.DiscardOutBuffer ();
DataList = Data.Split (SEP, System.StringSplitOptions.RemoveEmptyEntries);
//int count = 0;
foreach (string s in DataList) {
string[] ThisData;
//count++;
//Debug.Log (count);
ThisData = s.Split (SEPB, System.StringSplitOptions.RemoveEmptyEntries);
//Debug.Log (s + " | " +ThisData[0] + " | " +ThisData[1] );
// try {
if (ThisData [0] == "W") {
w = (float.Parse (ThisData [1]));
//Debug.Log ("W");
if (ThisData [0] == "X") {
x = (float.Parse (ThisData [1]));
//Debug.Log ("X");
if (ThisData [0] == "Y") {
y = (float.Parse (ThisData [1]));
//Debug.Log ("Y");
if (ThisData [0] == "Z") {
z = (float.Parse (ThisData [1]));
//Debug.Log ("Z");
// } catch {
transform.rotation = Quaternion.Euler (y, x, z);
When it first starts, i send a character from unity to activate the sensor.
All this, kind of works ok. My issue is, is there a better way to do this. Can i make it more precise.
More importantly, say i turn it upside dow, things start to go odd and it doesnt recreate the rotation properly at all.
I know people have made mocap using this sensor before, i just dont get how.
