MPU6050
Hello, I am experimenting the MPU6050 by following this tutorial http://diyhacking.com/arduino-mpu-6050-imu-sensor-tutorial/. Everything works fine. But I am puzzled the the INT output which is suppose to connect Arduino pin D2, however, when I disconnect it, the MPU6050 is still working jut fine. So what is the purpose of this INT?
The 'dmp' example puts firmware into the MPU-6050 and uses the FIFO of the MPU-6050 and the INT (interrupt). The interrupt tells the Arduino that there is new data in the FIFO, and the Arduino will retrieve it.
The simple example does not use the interrupt.
