I am looking for a good Gyro/acc meter and with all the queries do, the 6050 keeps popping up.
However, the libraries seem to be for advanced programmers.
is there a easier model that I can use for logging the movement of an RC car?
You can stick a pin on the wheels of the car and have the pin close a switch for each wheel rotation and then count wheel rotations do some math with wheel diameter and calculate distance traveled, per wheel, and so and and so forth or use a MMU with a library.
If by "movement" you mean distance traveled or position, an IMU won't be useful.
If you just want "air time" or "wow that was a big impact with the wall, I wonder how many G's it was?" then you only need an accelerometer. I like the ADXL345 a lot.
No, i want to log the roll/pitch of the car in comparison to the commands I give the car.
Sareno:
Sareno:
Is that all or do you have more requirements that you have not given out? An MUP6050 would work well. A accelerometer module would also work.
