MPU6050_DMP6 problem nothing in serial monitor
I have the “Wire.h”, “I2Cdev.h” & “MPU6050.h” library installed.
And I’ve tested the “IMU_Z” and “MPU6050-Raw” sketches and they both seem to work fine. based on what i can see on the serial monitor.
however the “MPU6050_DMP6” sketch uploads ok, but when i open the serial monitor all i get is about ten charictors of raw data and then the feed ends.
can anyone tell me what the problem is?
thanks
MPU6050_DMP6.ino (15.7 KB)
Yes. You failed to post your code.
I've added the sketch as an attchment at the moment, but how do upload the sketch so it has it's own scrolling text box? like ive seen others do?
I’ve added the sketch as an attchment at the moment
You changed your initial post, to make me look like a fool. Now, you want me to answer more questions? I’ll pass.
wtf!!! no one is trying to make u look like a fool! Your suffering from paranoia my friend.
i did put the code in the original post after your comment. Because it made more scene to have it with the question at the top of the page. It didnt even cross my mind that doing so might be interpreted as some sort of dis.
