MPU9150 erreur code
Bonsoir
Désolé de vous déranger encore, quelqu’un peut m’aider à trouver l’erreur dans ce code svp :slight_smile:
(Code tags added by moderator)
#define MPU9150_DEFAULT_ADDRESS 0x68
#define MPU9150_ACCEL_XOUT_H 0x3B
#define MPU9150_TEMP_OUT_H 0x41
#define MPU9150_GYRO_XOUT_H 0x43
#define MPU9150_PWR_MGMT_1 0x6B
void
mpu9150_setup(void)
 /* clear the SLEEP bit to start the sensor */
 uint8_t reg[2] = {MPU9150_PWR_MGMT_1, 0};
 twi_master_setup(); /* i2c to master mode */
 twi_write_bytes((MPU9150_DEFAULT_ADDRESS << 1), 2, reg);
* @return temperature in degrees C = (TEMP_OUT signed / 340) + 35
int16_t
mpu9150_read_temperature(void)
 volatile uint8_t buffer[2] = { 0, 0 };
 uint8_t reg = MPU9150_TEMP_OUT_H;
 twi_read_bytes(MPU9150_DEFAULT_ADDRESS << 1, &reg, 2, buffer);
 int16_t temperature;
 temperature = ((buffer[0] << 8) + buffer[1]);
 temperature /= 340;
 temperature += 35;
 return temperature;
typedef struct
 int16_t x;
 int16_t y;
 int16_t z;
} x_y_z;
x_y_z
mpu9150_read_gyroscope(void)
 volatile uint8_t buffer[6];
 uint8_t reg = MPU9150_GYRO_XOUT_H;
 twi_read_bytes(MPU9150_DEFAULT_ADDRESS << 1, &reg, 6, buffer);
 x_y_z gyro;
 gyro.x = (buffer[0] << 8) + buffer[1];
 gyro.y = (buffer[2] << 8) + buffer[3];
 gyro.z = (buffer[4] << 8) + buffer[5];
 return gyro;
x_y_z
mpu9150_read_accelerometer(void)
 uint8_t reg = MPU9150_ACCEL_XOUT_H;
 x_y_z accel;
 accel.x = (buffer[0] << 8) + buffer[1];
 accel.y = (buffer[2] << 8) + buffer[3];
 accel.z = (buffer[4] << 8) + buffer[5];
 return accel;
void
setup(void)
 usart_0_setup();
 usart_0_transmitter_enable();
 mpu9150_setup();
int
main(void)
 setup();
 _delay_ms(1000);
 while (1)
     _delay_ms(1000);
     int16_t t = mpu9150_read_temperature();
     usart_0_transmit(t >> 8);
     usart_0_transmit(t);
     _delay_ms(1000);
     x_y_z gyro = mpu9150_read_gyroscope();
     usart_0_transmit(gyro.x >> 8);
     usart_0_transmit(gyro.x);
     usart_0_transmit(gyro.y >> 8);
     usart_0_transmit(gyro.y);
     usart_0_transmit(gyro.z >> 8);
     usart_0_transmit(gyro.z);
 _delay_ms(1000);
     x_y_z acc = mpu9150_read_accelerometer();
     usart_0_transmit(acc.x >> 8);
     usart_0_transmit(acc.x);
     usart_0_transmit(acc.y >> 8);
     usart_0_transmit(acc.y);
     usart_0_transmit(acc.z >> 8);
Mets ton code entre balise stp, c'est difficilement lisible
Voilà:
" #define MPU9150_DEFAULT_ADDRESS 0x68
void
mpu9150_setup(void)
  • @return temperature in degrees C = (TEMP_OUT signed / 340) + 35
    int16_t
temperature /= 340;
temperature += 35;
return temperature;
typedef struct
int16_t x;
int16_t y;
int16_t z;
} x_y_z;
x_y_z
x_y_z gyro;
return gyro;
x_y_z
x_y_z accel;
return accel;
void
setup(void)
usart_0_setup();
mpu9150_setup();
int
main(void)
setup();
_delay_ms(1000);
while (1)
_delay_ms(1000);
_delay_ms(1000);
_delay_ms(1000);
Je suis désolé il m'a mit des smiley partout
Svp help me :S
Bonjour,
Yasso92: Je suis désolé il m'a mit des smiley partout
Svp help me :S
Ce n'est pour rien que l'on te dit de mettre le code entre balises : Voir ici
Si tu nous dit pas le message d'erreur on pourra pas faire grand chose.
Merci, je ne le savais pas :S
Voilà l’erreur:
Arduino : 1.6.5 (Windows 8.1), Carte : "Arduino Uno"
xbee_pro_servo_motor:12: error: 'x_y_z' does not name a type
xbee_pro_servo_motor:14: error: 'x_y_z' does not name a type
xbee_pro_servo_motor.ino: In function 'void mpu9150_setup()':
xbee_pro_servo_motor:13: error: 'twi_master_setup' was not declared in this scope
xbee_pro_servo_motor:14: error: 'twi_write_bytes' was not declared in this scope
xbee_pro_servo_motor.ino: In function 'int16_t mpu9150_read_temperature()':
xbee_pro_servo_motor:26: error: 'twi_read_bytes' was not declared in this scope
xbee_pro_servo_motor.ino: In function 'x_y_z mpu9150_read_gyroscope()':
xbee_pro_servo_motor:50: error: 'twi_read_bytes' was not declared in this scope
xbee_pro_servo_motor.ino: In function 'x_y_z mpu9150_read_accelerometer()':
xbee_pro_servo_motor:65: error: 'twi_read_bytes' was not declared in this scope
xbee_pro_servo_motor.ino: In function 'void setup()':
xbee_pro_servo_motor:77: error: 'usart_0_setup' was not declared in this scope
xbee_pro_servo_motor:78: error: 'usart_0_transmitter_enable' was not declared in this scope
xbee_pro_servo_motor.ino: In function 'int main()':
xbee_pro_servo_motor:93: error: 'usart_0_transmit' was not declared in this scope
  Ce rapport contiendrait plus d'informations si l'option
  "Montrer les informations de sortie pendant la compilation"
  était activée dans Fichier > Préférences.
ça c’est le code:
void
mpu9150_setup(void)
int16_t
 temperature /= 340;
 temperature += 35;
 return temperature;
typedef struct
 int16_t x;
 int16_t y;
 int16_t z;
} x_y_z;
x_y_z
 x_y_z gyro;
 return gyro;
x_y_z
 x_y_z accel;
 return accel;
void
setup(void)
 usart_0_setup();
 mpu9150_setup();
int
main(void)
 setup();
 _delay_ms(1000);
 while (1)
     _delay_ms(1000);
     _delay_ms(1000);
 _delay_ms(1000);
Merci encore!
Déjà le nom x_y_z ne lui plait pas. donc change de nom dans ton code et essaye de recompiler. Tu verras de ou viens ta deuxième erreur. Il suffit de lire le rapport d erreur. Et de corriger les erreurs une par une.
Justement le problème est que je ne sais par quoi le remplacer
Merci quand même :)
Pierre, Paul ou Jacques!
Peut importe… Temps que tu remplace x_y_z PARTOUT dans ton code par exemple par cliors (par ce que j en ai une) et tu verras que tu ne serras plus dérangé. Ce qui dérange dans le nom c est les “_” tout simplement.
Merci de votre réponse
Donc je dois supprimer tous les "_"??
Parce que j'ai changer le "x_y_z" mais c'est encore pire ;/
