MPU9250/6500 library problem
I'm trying to use MPU9250/6500 to get xyz axis
the code I got from GitHub
#include "Wire.h"
#include "I2C.h"
#define MPU9250_IMU_ADDRESS 0x68
#define MPU9250_MAG_ADDRESS 0x0C
#define GYRO_FULL_SCALE_250_DPS  0x00
#define GYRO_FULL_SCALE_500_DPS  0x08
#define GYRO_FULL_SCALE_1000_DPS 0x10
#define GYRO_FULL_SCALE_2000_DPS 0x18
#define ACC_FULL_SCALE_2G  0x00
#define ACC_FULL_SCALE_4G  0x08
#define ACC_FULL_SCALE_8G  0x10
#define ACC_FULL_SCALE_16G 0x18
#define TEMPERATURE_OFFSET 21 // As defined in documentation
#define INTERVAL_MS_PRINT 1000
#define G 9.80665
struct gyroscope_raw {
  int16_t x, y, z;
} gyroscope;
struct accelerometer_raw {
  int16_t x, y, z;
} accelerometer;
struct magnetometer_raw {
  int16_t x, y, z;
  struct {
    int8_t x, y, z;
  } adjustment;
} magnetometer;
struct temperature_raw {
  int16_t value;
} temperature;
struct {
  struct {
    float x, y, z;
  } accelerometer, gyroscope, magnetometer;
  float temperature;
} normalized;
unsigned long lastPrintMillis = 0;
  Wire.begin();
  I2CwriteByte(MPU9250_IMU_ADDRESS, 27, GYRO_FULL_SCALE_1000_DPS); // Configure gyroscope range
  I2CwriteByte(MPU9250_IMU_ADDRESS, 28, ACC_FULL_SCALE_2G);        // Configure accelerometer range
  I2CwriteByte(MPU9250_IMU_ADDRESS, 55, 0x02); // Set by pass mode for the magnetometers
  I2CwriteByte(MPU9250_IMU_ADDRESS, 56, 0x01); // Enable interrupt pin for raw data
  setMagnetometerAdjustmentValues();
  //Start magnetometer
  I2CwriteByte(MPU9250_MAG_ADDRESS, 0x0A, 0x12); // Request continuous magnetometer measurements in 16 bits (mode 1)
  if (isImuReady()) {
    readRawImu();
    normalize(gyroscope);
    normalize(accelerometer);
    normalize(temperature);
  if (isMagnetometerReady()) {
    readRawMagnetometer();
    normalize(magnetometer);
  if (currentMillis - lastPrintMillis > INTERVAL_MS_PRINT) {
    Serial.print("TEMP:\t");
    Serial.print(normalized.temperature, 2);
    Serial.print("\xC2\xB0"); //Print degree symbol
    Serial.print("C");
    Serial.print("GYR (");
    Serial.print("/s):\t");
    Serial.print(normalized.gyroscope.x, 3);
    Serial.print("\t\t");
    Serial.print(normalized.gyroscope.y, 3);
    Serial.print(normalized.gyroscope.z, 3);
    Serial.print("ACC (m/s^2):\t");
    Serial.print(normalized.accelerometer.x, 3);
    Serial.print(normalized.accelerometer.y, 3);
    Serial.print(normalized.accelerometer.z, 3);
    Serial.print("MAG (");
    Serial.print("\xce\xbc"); //Print micro symbol
    Serial.print("T):\t");
    Serial.print(normalized.magnetometer.x, 3);
    Serial.print(normalized.magnetometer.y, 3);
    Serial.print(normalized.magnetometer.z, 3);
    lastPrintMillis = currentMillis;
this is the error message
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\Cloud\OneDrive\Desktop\master degree\arduino code\xyz\xyz.ino: In function 'void setup()':
xyz:64:3: error: 'setMagnetometerAdjustmentValues' was not declared in this scope
C:\Users\Cloud\OneDrive\Desktop\master degree\arduino code\xyz\xyz.ino: In function 'void loop()':
xyz:74:7: error: 'isImuReady' was not declared in this scope
if (isImuReady()) {
xyz:75:5: error: 'readRawImu' was not declared in this scope
 readRawImu();
xyz:77:5: error: 'normalize' was not declared in this scope
C:\Users\Cloud\OneDrive\Desktop\master degree\arduino code\xyz\xyz.ino:77:5: note: suggested alternative: 'normalized'
 normalized
xyz:82:7: error: 'isMagnetometerReady' was not declared in this scope
C:\Users\Cloud\OneDrive\Desktop\master degree\arduino code\xyz\xyz.ino:82:7: note: suggested alternative: 'magnetometer_raw'
   magnetometer_raw
xyz:83:5: error: 'readRawMagnetometer' was not declared in this scope
C:\Users\Cloud\OneDrive\Desktop\master degree\arduino code\xyz\xyz.ino:83:5: note: suggested alternative: 'magnetometer'
 magnetometer
xyz:85:5: error: 'normalize' was not declared in this scope
C:\Users\Cloud\OneDrive\Desktop\master degree\arduino code\xyz\xyz.ino:85:5: note: suggested alternative: 'normalized'
 normalized
exit status 1
option enabled in File -> Preferences.
Where from github? Link please.
Maybe the code was part of a library and you did not donwload the library. Maybe there were multiple files and you only downloaded the one that you showed.
the error is correct there is no setMagnetometerAdjustmentValues(); function. Where did you get the code from? Perhaps you did not copy the entire code?
thank you for replying
I tried to find the link but unfortunately I didn't find it
can you assist me with problem in the code
I tried this one it, worked but I don't understand them
 #include <Wire.h>
#include <TimerOne.h>
#define    MPU9250_ADDRESS            0x68
#define    MAG_ADDRESS                0x0C
#define    ACC_FULL_SCALE_2_G        0x00
#define    ACC_FULL_SCALE_4_G        0x08
#define    ACC_FULL_SCALE_8_G        0x10
#define    ACC_FULL_SCALE_16_G       0x18
// This function read Nbytes bytes from I2C device at address Address.
// Put read bytes starting at register Register in the Data array.
void I2Cread(uint8_t Address, uint8_t Register, uint8_t Nbytes, uint8_t* Data)
  // Set register address
  Wire.beginTransmission(Address);
  Wire.write(Register);
  Wire.endTransmission();
  // Read Nbytes
  Wire.requestFrom(Address, Nbytes);
  uint8_t index=0;
  while (Wire.available())
    Data[index++]=Wire.read();
// Write a byte (Data) in device (Address) at register (Register)
void I2CwriteByte(uint8_t Address, uint8_t Register, uint8_t Data)
  Wire.write(Data);
// Initial time
long int ti;
volatile bool intFlag=false;
// Initializations
  // Arduino initializations
  Wire.begin();
  // Set accelerometers low pass filter at 5Hz
  I2CwriteByte(MPU9250_ADDRESS,29,0x06);
  // Set gyroscope low pass filter at 5Hz
  I2CwriteByte(MPU9250_ADDRESS,26,0x06);
  I2CwriteByte(MPU9250_ADDRESS,27,GYRO_FULL_SCALE_1000_DPS);
  // Configure accelerometers range
  I2CwriteByte(MPU9250_ADDRESS,28,ACC_FULL_SCALE_4_G);
  I2CwriteByte(MPU9250_ADDRESS,0x37,0x02);
  I2CwriteByte(MAG_ADDRESS,0x0A,0x16);
   pinMode(13, OUTPUT);
  Timer1.initialize(10000);         // initialize timer1, and set a 1/2 second period
  Timer1.attachInterrupt(callback);  // attaches callback() as a timer overflow interrupt
  // Store initial time
  ti=millis();
// Counter
long int cpt=0;
void callback()
  intFlag=true;
  digitalWrite(13, digitalRead(13) ^ 1);
// Main loop, read and display data
  while (!intFlag);
  intFlag=false;
  // Display time
  Serial.print (millis()-ti,DEC);
  Serial.print ("\t");
  // _______________
  // ::: Counter :::
  // Display data counter
//  Serial.print (cpt++,DEC);
//  Serial.print ("\t");
  // ____________________________________
  // :::  accelerometer and gyroscope :::
  // Read accelerometer and gyroscope
  uint8_t Buf[14];
  I2Cread(MPU9250_ADDRESS,0x3B,14,Buf);
  // Create 16 bits values from 8 bits data
  // Accelerometer
  int16_t ax=-(Buf[0]<<8 | Buf[1]);
  int16_t ay=-(Buf[2]<<8 | Buf[3]);
  int16_t az=Buf[4]<<8 | Buf[5];
  // Gyroscope
  int16_t gx=-(Buf[8]<<8 | Buf[9]);
  int16_t gy=-(Buf[10]<<8 | Buf[11]);
  int16_t gz=Buf[12]<<8 | Buf[13];
    // Display values
  // Accelerometer
  Serial.print (ax,DEC);
  Serial.print (ay,DEC);
  Serial.print (az,DEC);
  // Gyroscope
  Serial.print (gx,DEC);
  Serial.print (gy,DEC);
  Serial.print (gz,DEC);
  // :::  Magnetometer :::
  // Read register Status 1 and wait for the DRDY: Data Ready
  uint8_t ST1;
  do
    I2Cread(MAG_ADDRESS,0x02,1,&ST1);
  while (!(ST1&0x01));
  // Read magnetometer data
  uint8_t Mag[7];
  I2Cread(MAG_ADDRESS,0x03,7,Mag);
  // Magnetometer
  int16_t mx=-(Mag[3]<<8 | Mag[2]);
  int16_t my=-(Mag[1]<<8 | Mag[0]);
  int16_t mz=-(Mag[5]<<8 | Mag[4]);
  // Magnetometer
  Serial.print (mx+200,DEC);
  Serial.print (my-70,DEC);
  Serial.print (mz-700,DEC);
  // End of line
  Serial.println("");
//  delay(100);
