Hello,
I’m struggling to get MP9250 work with Arduino via SPI. The skecth is:
#include <SPI.h>
#define SDA_PIN 10 // Configurable, see typical pin layout above
#define SPICLOCK (4000000u)
void printCharWithLeading(char c) {
for (unsigned int mask = 0x80; mask; mask >>= 1) {
Serial.print(mask&c ? '1':'0');
byte SPIwriteRegister(char reg, byte b) {
Serial.print ("SPIwriteRegister: ");
Serial.print(reg, HEX);
Serial.print (" - ");
printCharWithLeading(b);
SPI.beginTransaction(SPISettings(SPICLOCK, MSBFIRST, SPI_MODE3)); // Set the settings to work with SPI bus
digitalWrite(SDA_PIN, LOW); // Select slave
SPI.transfer(reg); //
SPI.transfer(b); // Write data
SPI.endTransaction(); // Stop using the SPI bus
return;
} // End SPIwriteRegister
byte SPIreadRegister(char reg) {
Serial.print ("SPIreadRegister: ");
Serial.println(reg, HEX);
byte value = 0xFF;
SPI.transfer(0x80 | reg); // MSB == 1 is for reading. LSB is not used in address. Datasheet section 8.1.2.3.
value = SPI.transfer(0); // Read the value back. Send 0 to stop reading.
digitalWrite(SDA_PIN, HIGH); // Release slave again
return value;
} // End SPIreadRegister
void initMPU9250 () {
byte error;
char c;
// Set the chipSelectPin as digital output, do not select the slave yet
Serial.print ("SDA_PIN: ");
Serial.println(SDA_PIN);
pinMode (SDA_PIN, OUTPUT);
// Toggle CS pin to lock in SPI mode
delay(1);
delay(1);
// write Register PWR_MGMNT_1 (0x6B) / 0xb00000001
c = SPIwriteRegister(0x6B, 0xb00000001);
// read Register PWR_MGMNT_1 (0x6B)
printCharWithLeading(c);
c = SPIreadRegister(0x6B);
Serial.print("MPU9250 Power-Management-Register : ");
Serial.println("start setup");
SPI.begin();
initMPU9250();
Serial.println("end setup");
The wiing is like this
Arduino MPU9250
CS/SS/SDA D10 NCS
SCK D13 SCL
MOSI D11 SDA
MISO D12 AD0
GND FSYNC
Writing data is o.k. - I checked it by I2C, and the new data is written correctly. But I cannot read data. The returned value is always 0. MISO-Arduino is working fine with another devices.
What am I doing wrong (MCU: Arduino Nano, IDE: 1.8.16)?
