Mpu9255 cant get z axis data
I have that MPU9255: https://himalayansolution.com/product/mpu-92-65-gyroscope-and-accelerometer-module-3-axis
I want to angle of yaw movement and here is my code:
#include <SoftwareWire.h>
SoftwareWire wire(2,3);
const int SENSOR_ADDRESS = 0x68;
  wire.begin();
  wire.beginTransmission(SENSOR_ADDRESS);
  wire.write(0x6B);
  wire.write(0x00);
  wire.endTransmission(true);
  delay(50);
  wire.write(0x1C);
  wire.write(0x00);
  wire.write(0x3B);
  wire.endTransmission(false);
  wire.requestFrom(SENSOR_ADDRESS, 6, true);
  int16_t xAxisFull = (wire.read() << 8 | wire.read());
  int16_t yAxisFull = (wire.read() << 8 | wire.read());
  int16_t zAxisFull = (wire.read() << 8 | wire.read());
  float xAxisFinal = (float)xAxisFull / 16384.0;
  float yAxisFinal = (float)yAxisFull / 16384.0;
  float zAxisFinal = (float)zAxisFull / 16384.0;
  Serial.print("x Axis = ");
  Serial.println(xAxisFinal);
  Serial.print("Y Axis = ");
  Serial.println(yAxisFinal);
  Serial.print("Z Axis = ");
  Serial.println(zAxisFinal);
  Serial.println("-------------");
and here is my output:
x Axis = 0.00
Y Axis = 0.02
Z Axis = 0.93
There is no problem to get roll and pitch angles but when sensor make yaw movement there is no change in z axis value.
And that is the output when sensor make roll movement:
x Axis = 1.00
Y Axis = 0.02
Z Axis = -0.13
z axis value is decreasing same amount as increase amount of x axis value. And this is the pitch movement output:
x Axis = 0.05
Y Axis = 0.99
Z Axis = -0.14
Same as roll movement.
How can I get angle of yaw movement.
The magnetometer can be used as a compass, to measure yaw.
The accelerometer can measure only pitch and roll, as described here: How_to_Use_a_Three-Axis_Accelerometer_for_Tilt_Sensing-DFRobot
Accelerometer is 3 axis:
Forward/backward
Left/Right
Up/down
Edit: Gyro should do:
Pitch
Roll
Yaw
You can make a single axis gyro with 2 accelerometers using a differential output.
Six accelerometers would do all 3 gyro axes. I could boil that down to 5.
