I am using a MPX5100 pressure sensor, a Arduino Uno, LCD, and two air pumps. This setup is to read pressure or flow through a 2cycle fuel mixture needle valve using mmhg standard. The calculation I am using for the MPX5100 is what I got from some other code, but the problem is it isn't reading correctly. It is off by 38mmhg verified with a calibrated meter from work. Everything I try doesn't work. I have tried changing the upper calibration number but that causes the code to not read consistent number like example 50,51,52,53,54,55 instead it is 51,52, 54,55 so it misses numbers throughout the range.
The picture just shows a different LCD.
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
//int rawValue; // A/D readings
int offset = 30; // zero pressure adjust (~30-72)
int fullScale = 819; // 819 max pressure adjust (~798-840),Calibrate high pressure reading.
float pressure; // final pressure in mmHg
int Battery; // battery % of use
uint32_t rawValue; // new average code
int rawAccumulator; // new average code
int filteredValue; // new average code
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
rawValue = analogRead(A0);
pressure = (filteredValue - offset) * 650.0 / (fullScale - offset); // Replaced rawValue with filteredValue. 650.0 for calibrated pressure conversion
Battery = analogRead(A1) / 9.00; // Display battery percentage at max 100%
// New code for averaging - On each pass, it subtracts 1/8 of the total rawAccumulator value, then adds in the current rawValue.
// So over time, the rawAccumulator value will converge on 8x the average raw value.
// Then it takes 1/8 of the rawAccumulator value as the filteredValue.
rawAccumulator -= (rawAccumulator >> 2); // new average code. Can change 3 to 2 for less or 3 to 4 for more averaging.
rawAccumulator += rawValue; // new average code
filteredValue = rawAccumulator >> 2; // new average code. Can change 3 to 2 for less or 3 to 4 for more averaging.
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
if (pressure < 0)
lcd.setCursor(0 , 0);
lcd.print("FLOW RATE:");
lcd.print("0");
lcd.print(pressure, 0);
lcd.print(" ");
if (Battery > 65)
lcd.setCursor(0 , 1);
lcd.print("BATTERY:");
lcd.print(Battery);
lcd.print("% ");
lcd.print("*CHARGE BATTERY*");
delay(200);
