MQ 135 value
Hello i,m try mq 135 air sensor
But it read 0,02 ppm ?
include "MQ135.h"
define ANALOGPIN 0
float airthreshold[3] = { 400, 400, 800};
// Initialize the gas Sensor MQ135 gasSensor = MQ135(ANALOGPIN);
void setup() { // start the LEDs
//Set up the serial terminal Serial.begin(9600); } void loop() { float ppm = gasSensor.getPPM(); Serial.print(" CO2: "); Serial.print(ppm); Serial.println(" ppm ");
delay(1000); }
This is the code
Is 0,02 ppm good reading
Thanks
moderator: please use code tags - and use CTRL-T in the IDE for proper indenting
also a link to the library used will be helpful
What did you expect? is it too low/high
What does the datasheet of the sensor describe as unit?
This website is a good website. Has experienced an increase
hi, this solves the question: https://hackaday.io/project/3475-sniffing-trinket
