MQ-2 Gas Sensor
Hi everyone ! ,
In my studies, I have a project where I use the MQ-2 gas sensor.
here is the program I use:
const int analogInPin = A0;  // Analog input pin that the potentiometer is attached to
const int ledPin = 13;                 // LED connected to digital pin 13
int sensorValue = 0;
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
 sensorValue = analogRead(analogInPin);
  // determine alarm status
  if (sensorValue >= 250)
    digitalWrite(ledPin, HIGH);   // sets the LED on
  digitalWrite(ledPin, LOW);    // sets the LED off
  // print the results to the serial monitor:
  Serial.print("sensor = " );
  Serial.println(sensorValue);
  delay(750);
the program is to light a LED when the gas rate is greater than 250ppm.
But I have a problem;
that there is an equation for an analog value to a value ppm?
Then datasheet says that this sensor can capture several gas but I have only one value,
Can we have several value display simultaneously?
If someone has an MQ-2 program that works, I'm interested
thank you in advance :slight_smile:
Jeremy
Hi, welcome to the forum.
This is some basic information : Arduino Playground - MQGasSensors
Bonjour j'ai le même problème que toi pour un de mes collègues il le résout et je te le passe
jean lc
Hello,
See discussion here for calibration in open air:
Here are my libraries with curves calculated from datasheets :
The MQ series are very cheap, variable, and change their values in time. It is a good entry point but no more after. Oftern the knob on the pre-assemble boards are only sed for the digital signal and its led on the board.
For H2, I am now considering MIcS sensors.
Hello,
Thank you for your reply !
I looked your libraries with curves calculated from datasheets :
But I have the MQ2 gas sensor only; Have you got functional program epierre ?
Jeremy
