MQ gas sensors
I am planning to monitor the air quality by measuring the concentration of CO, LPG and Methane gases with MQ sensors that are linked below.
I came across the tutorial posted on Arduino website linked below.
Arduino Playground - MQGasSensors. Some parts on the tutorial are not clear, they are listed below.
  1. “The heater may not be connected directly to an output-pin of the Arduino, since it uses too much current for that.”
    Does it mean that I should not connect it to any of the digital pins ? Can I connect it to the 5 volts from the Arduino board ? or should I use external power supply for this.
  2. “A time of 12 or 24 hours is usually used for the burn-in time.”
    Do I need to supply 5 volts to the sensors for 12 hours?
  3. “In some special cases a specific burn-in is needed. See the datasheet if the sensor needs such a specific burn-in.”
    Do I need the specific burn in for MQ7, MQ6 and MQ4.
  4. Do I need a special library for the sensor, or can I only use the analogRead
That is exactly what it means.
Read the data sheet for the sensor. How much current does the heater need? An external supply is certainly a better idea, if not mandatory.
  1. "A time of 12 or 24 hours is usually used for the burn-in time."
Wasn't that what it said?
  1. "In some special cases a specific burn-in is needed. See the datasheet if the sensor needs such a specific burn-in."
Did you do as it said, and see the f**king data sheet? THAT is what an engineer does.
  1. Do I need a special library for the sensor, or can I only use the analogRead
Same answer as #3.
