MQ135 with ESP 32
I'm using MQ135 with ESP32 but it's showing NaN value for PPM. I changed the type of PPM to Integer and this is what I got.
code:
#include "MQ135.h"
#define PIN_MQ135 32
MQ135 mq135_sensor(PIN_MQ135);
float temperature = 21.0; // Assume current temperature. Recommended to measure with DHT22
float humidity = 25.0; // Assume current humidity. Recommended to measure with DHT22
  float rzero = mq135_sensor.getRZero();
  float correctedRZero = mq135_sensor.getCorrectedRZero(temperature, humidity);
  float resistance = mq135_sensor.getResistance();
  float ppm = mq135_sensor.getPPM();
  float correctedPPM = mq135_sensor.getCorrectedPPM(temperature, humidity);
  Serial.print("MQ135 RZero: ");
  Serial.print(rzero);
  Serial.print("\t Corrected RZero: ");
  Serial.print(correctedRZero);
  Serial.print("\t Resistance: ");
  Serial.print(resistance);
  Serial.print("\t PPM: ");
  Serial.print(ppm);
  Serial.print("\t Corrected PPM: ");
  Serial.print(correctedPPM);
  Serial.println("ppm");
  delay(300);
int PPM
Try here
@farhan74, your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advise on) your project :wink: See About the Installation & Troubleshooting category.
