when I compile this code, error like this "Compilation error: conversion from 'const uint8_t {aka const unsigned char}' to 'String' is ambiguous"
please solve this problem OTL
There is not such a thing; in future please post the complete error message using code tags; IDE 1.x (where you posted this) gives a button "copy error messages" at the right above the output window to make life easy for you; the only thing it does not do is adding the code tags.
C:\Users\장태영\AppData\Local\Temp.arduinoIDE-unsaved20231023-26684-lk55mw.ybhbj\sketch_nov23a\sketch_nov23a.ino:9:37: error: conversion from 'const uint8_t {aka const unsigned char}' to 'String' is ambiguous
In file included from C:\Users\���¿�\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino/Arduino.h:232:0,
from C:\Users\���¿�\AppData\Local\Temp\arduino\sketches\CBEFCE95EFD67073B85F38719F1EAF5C\sketch\sketch_nov23a.ino.cpp:1:
C:\Users\���¿�\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino/WString.h:61:2: note: candidate: String::String(const __FlashStringHelper*)
String(const __FlashStringHelper str);
C:\Users\���¿�\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino/WString.h:61:2: note: conversion of argument 1 would be ill-formed:
C:\Users\���¿�\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino/WString.h:59:2: note: candidate: String::String(const char)
String(const char *cstr = "");
C:\Users\���¿�\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino/WString.h:59:2: note: conversion of argument 1 would be ill-formed:
In file included from C:\Users\장태영\AppData\Local\Temp.arduinoIDE-unsaved20231023-26684-lk55mw.ybhbj\sketch_nov23a\sketch_nov23a.ino:4:0:
C:\Users\���¿�\Documents\Arduino\libraries\MQUnifiedsensor\src/MQUnifiedsensor.h:16:5: note: initializing argument 1 of 'MQUnifiedsensor::MQUnifiedsensor(String, float, int, int, String)'
MQUnifiedsensor(String Placa = "Arduino", float Voltage_Resolution = 5, int ADC_Bit_Resolution = 10, int pin = 1, String type = "CUSTOM MQ");
C:\Users\장태영\AppData\Local\Temp.arduinoIDE-unsaved20231023-26684-lk55mw.ybhbj\sketch_nov23a\sketch_nov23a.ino: In function 'void loop()':
C:\Users\장태영\AppData\Local\Temp.arduinoIDE-unsaved20231023-26684-lk55mw.ybhbj\sketch_nov23a\sketch_nov23a.ino:22:14: error: 'class Adafruit_Fingerprint' has no member named 'fingerPresent'; did you mean 'fingerSearch'?
C:\Users\장태영\AppData\Local\Temp.arduinoIDE-unsaved20231023-26684-lk55mw.ybhbj\sketch_nov23a\sketch_nov23a.ino:26:16: error: 'class Adafruit_Fingerprint' has no member named 'verify'
C:\Users\장태영\AppData\Local\Temp.arduinoIDE-unsaved20231023-26684-lk55mw.ybhbj\sketch_nov23a\sketch_nov23a.ino:30:50: error: 'class MQUnifiedsensor' has no member named 'read'
C:\Users\장태영\AppData\Local\Temp.arduinoIDE-unsaved20231023-26684-lk55mw.ybhbj\sketch_nov23a\sketch_nov23a.ino:51:12: error: 'class Adafruit_Fingerprint' has no member named 'addModel'; did you mean 'loadModel'?
exit status 1
