Mq3 sensor -> LED stripe
Hi HALLO
we are making alcohol mask with MQ3 alcohol sensor!
we will going to use 1m digital LED stripe, adafriut Neopixels.
If the alcohol level is over than 500, 1-20 pixels will turn on as RED color.
100<alcohol level<500 - 21~40 YELLOW color.
under 100 alcohol level - 41~60 GREEN color.
(IN THE ATTACHED PICTURE ARDUINO IS NOT TURNED ON, WE KNOW :slight_smile: )
This is the code that we used:
int mq3_analogPin = A0; // connected to the output pin of MQ3
#define PIN 6
// remenber 100 to 1000 ohm resistor in series with each led
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
Serial.begin(9600); // open serial at 9600 bps
// give ample warmup time for readings to stabilize
int mq3_value = analogRead(mq3_analogPin);
Serial.println(mq3_value);
if (mq3_value<100)
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, 0,255,0);
strip.show();
delay(50);
} else if(mq3_value>500)
strip.setPixelColor(i, 255,0,0);
strip.show();
delay(50);
strip.setPixelColor(i, 255,255,0);
strip.show();
delay(50);
delay(100); //Just here to slow down the output.
It is not working now, and we dont know if it is because of the code or the connection to the arduino/power supply, someone can maybe help?
Thank you in advance!
