MQTT connection failed! Error code = -1 <<Solved>>
I am using ArduinoMqttClient library, On running a loop every 70 seconds, it connects the first time and sends the message, then on the second message and after retries every 5 mins, I am getting
I cannot find any reference on the interweb for (-1) error code,
Anyone any ideas??
Thanks in advance.
Any code?
Read How to use this forum, and post your sketch- all of it- using code tags.
#include <MKRGSM.h>
#include <ArduinoMqttClient.h>
GSM gsmAccess;
GSMClient gsmClient;
MqttClient mqttClient(gsmClient);
const char apn[]      = "data.com";
const char login[] = "";      // keep blank if not sure
const char password[] = "";      // keep blank if not sure
const char broker[] = "88.88.88.88";
int        port     = 1883;
const char topic[]  = "test2";
const char publishTopic[]  = "357520078007230";
void parseData(String dataToSend)
  mqttClient.setUsernamePassword("username", "password");
  Serial.print("Attempting to connect to the MQTT broker: ");
  Serial.println(broker);
  Serial.println("Sending data...");
     while (!mqttClient.connect(broker, port))
    Serial.print("MQTT connection failed! Error code = ");
    Serial.println(mqttClient.connectError());
    delay(600000);
   Serial.println("");
   Serial.println("You're connected to the MQTT broker!");
  // set the message receive callback
      mqttClient.beginMessage(publishTopic);
      mqttClient.print(dataToSend.c_str());
      mqttClient.endMessage();
      delay(20);
This is the code I am calling from the main script for MQTT connection. The main script only sets up GSM connection and gets a temperature reading.
nksky137:
#include <MKRGSM.h>
[/quote]
I don’t see anything wrong with the code but I have never used the ArduinoMqttClient library.
Try the PubSubClient library, which I suspect is a lot more commonplace here.
Thanks for all your help. The problem turned out to be a problem with the local SIM card operator. They were having some outage in the area, I switched provider and the problem has been rectified. Once again thanks.
This can be now closed.
