MQTT connection failing, serial monitor returns -2 in arduino ide
I m trying to send the dht22 temperature and humidity data to cloud mqtt. I m using ESP8266 as wifi module to send the data from the arduino uno to the server. The libraries i m using are : wifiesp, Pubsubclient and dht The problem i m facing is that the connection to the mqtt server gets failed and returns -2 on serial monitor, sometimes i face data packet send error(2) and socket error. I still dont know where i m making mistake. Please help.
#include "DHT.h"
#include <WiFiEspClient.h>
#include <WiFiEsp.h>
#include <WiFiEspUdp.h>
#include <PubSubClient.h>
#include "SoftwareSerial.h"
#define WIFI_AP "ssid"
#define WIFI_PASSWORD "password"
#define TOKEN "mqttusername"
#define PASS "mqttpassword"
// DHT
#define DHTPIN 5
#define DHTTYPE DHT22
char mqttServer[] = "m15.cloudmqtt.com";
// Initialize the Ethernet client object
WiFiEspClient espClient;
// Initialize DHT sensor.
DHT dht(DHTPIN, DHTTYPE);
PubSubClient client(espClient);
SoftwareSerial Serial1(10,11); // RX, TX
int status = WL_IDLE_STATUS;
unsigned long lastSend;
  // initialize serial for debugging
  dht.begin();
  InitWiFi();
  client.setServer( mqttServer, 17094 );
  lastSend = 0;
  //status = WiFi.status();
  if ( !client.connected() ) {
    reconnect();
  if ( millis() - lastSend > 1000 ) { // Update and send only after 1 seconds
    getAndSendTemperatureAndHumidityData();
    lastSend = millis();
  client.loop();
void getAndSendTemperatureAndHumidityData()
  Serial.println("Collecting temperature data.");
  // Reading temperature or humidity takes about 250 milliseconds!
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.print(" *C ");
  String temperature = String(t);
  String humidity = String(h);
  // Just debug messages
  Serial.print( "Sending temperature and humidity : [" );
  Serial.print( temperature ); Serial.print( "," );
  Serial.print( humidity );
  Serial.print( "]   -> " );
  // Prepare a JSON payload string
  String payload = "{";
  payload += "\"temperature\":"; payload += temperature; payload += ",";
  payload += "\"humidity\":"; payload += humidity;
  payload += "}";
  // Send payload
  char attributes[100];
  payload.toCharArray( attributes, 100 );
  client.publish( "esp8266/dht22", attributes );
  Serial.println( attributes );
void InitWiFi()
   // initialize serial for ESP module
  Serial1.begin(115200);
  // initialize ESP module
  WiFi.init(&Serial1);
  // check for the presence of the shield
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue
    while (false);
  // attempt to connect to WiFi network
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    // print the SSID of the network you're attached to
   //Serial.print("SSID: ");
   Serial.println(WiFi.SSID());
    // Connect to WPA/WPA2 network
    status = WiFi.begin(WIFI_AP, WIFI_PASSWORD);
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Connecting to CLOUD MQTT ...");
    // Attempt to connect (clientId, username, password)
    if ( client.connect("Arduino Uno Device", TOKEN, PASS) ) {
      Serial.println( "[DONE]" );
      Serial.print( "[FAILED] [ rc = " );
      Serial.print( client.state() );
      Serial.println( " : retrying in 5 seconds]" );
      // Wait 5 seconds before retrying
      delay( 5000 );
The log in the cloud mqtt says:
2019-01-04 10:51:28: Socket error on client Arduino Uno Device, disconnecting.
2019-01-04 10:51:48: New connection from 103.215.241.176 on port 17094.
2019-01-04 10:51:48: New client connected from 103.215.241.176 as Arduino Uno Device (c1, k15, u'ihiiwona').
2019-01-04 10:51:48: No will message specified.
2019-01-04 10:51:48: Sending CONNACK to Arduino Uno Device (0, 0)
2019-01-04 10:52:11: Client Arduino Uno Device has exceeded timeout, disconnecting.
2019-01-04 10:52:11: Socket error on client Arduino Uno Device, disconnecting.
2019-01-04 10:52:14: New connection from 103.215.241.176 on port 17094.
2019-01-04 10:52:14: New client connected from 103.215.241.176 as Arduino Uno Device (c1, k15, u'ihiiwona').
2019-01-04 10:52:14: No will message specified.
2019-01-04 10:52:14: Sending CONNACK to Arduino Uno Device (0, 0)
2019-01-04 10:52:26: Received PINGREQ from MQTT_FX_Client
2019-01-04 10:52:26: Sending PINGRESP to MQTT_FX_Client
2019-01-04 10:52:36: Client Arduino Uno Device has exceeded timeout, disconnecting.
2019-01-04 10:52:36: Socket error on client Arduino Uno Device, disconnecting.
2019-01-04 10:52:40: New connection from 103.215.241.176 on port 17094.
2019-01-04 10:53:26: Received PINGREQ from MQTT_FX_Client
2019-01-04 10:53:26: Sending PINGRESP to MQTT_FX_Client
2019-01-04 10:54:11: Client <unknown> has exceeded timeout, disconnecting.
2019-01-04 10:54:11: Socket error on client <unknown>, disconnecting.
