MQTT connecton - help to review code
Hi
my MQTT seems unstable, but I'm pretty shure connection is ok. I have a stable LAN use Ubiquity devises and my net is stable. And when I trigger the code I receive a MQTT package to Home assistant, 100%
Is there something in my MQTT code that triggers a reconnection?
Thanks up front!
I use this MQTT code:
if (!client.connected()) {
    while (!client.connected() && retryMQTT < maxRetryMQTT) {
      Serial.println("Connect to MQTT...");
      if (client.connect(mqtt_clientID, mqtt_username, mqtt_password)) {
        Serial.println("MQTT   IP 192.168.0.60:1883, web :8123");
        retryMQTT = 0; // Reset the retry count if the connection is successful
        MQTTstatus = "Connect to til HA";
        Serial.print("Error MQTT connection, Return Code = ");
        Serial.println(client.state());
        retryMQTT++;
        MQTTstatus = "Not connected to HA, RC = " + client.state();;
      //ESP.restart();
After reboot:
Connecting to LAN
WiFi connected
IP address:
192.168.0.140
Connect to MQTT...
After a while this happens on serial:
Connect to MQTT...
Connect to MQTT...
Connect to MQTT...
Connect to MQTT...
                Det renner vann, sender verdi:      6
                Det renner ikke vann, sender verdi: 0
                Det renner vann, sender verdi:      7
Connect to MQTT...
Connect to MQTT...
Connect to MQTT...
Connect to MQTT...
All code:
#include <ESP8266WiFi.h>
#include <PubSubClient.h>            // MQTT
const char* ssid = "LAN";      // Your WiFi network SSID
const char* password = "xxx";  // Your WiFi network password
const int buttonPin = D2; // D2 pin
int buttonState     = 0;      // variable for reading the button status
int lastButtonState = 0;  // variable to store the previous button state
int vannRennerFlagg = 0;
int previousState   = 0;
// MQTT
WiFiClient espClient;
PubSubClient client(espClient);
int    maxRetryMQTT         = 3;
int    retryMQTT            = 0;
String MQTTstatus           = "_";          // For å skrive til serial at kobling til HA er OK
const char* mqtt_username   = "yyy";           // MQTT username virker 2023.07.05
const char* mqtt_password   = "zzzz";   // MQTT password virker 2023.07.05
const char* mqtt_clientID   = "dam";                // MQTT client ID, må være unikt pr IoT
char vannRennerMsg[10];
//int vannRennerFlagg         = 0;
//uint8_t vannRennerFlagg       = 0;
IPAddress MQTTserver(192, 168, 0, 60);      //MQTT server IP
  Serial.begin(115200);    // initialize serial communication
  PrintFileNameDateTime();
  client.setServer(MQTTserver , 1883);         // MQTT server 192.168.0.60:1883 riktig ift mqtt mottak
  pinMode(buttonPin, INPUT);    // set the D2 pin as an input
  digitalWrite(buttonPin, LOW); // enable internal pull-down resistor
  // Connect to WiFi
  WiFi.begin(ssid, password);
  Serial.print("Connecting to ");
  Serial.println(ssid);
    Serial.print(".");
  // Print connection established
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  // kobler til mqtt
        retryMQTT++;
      //ESP.restart();                          // ###################### behold denne muligheten  se på versjon tidligere
  // read the state of the pushbutton value
  buttonState = digitalRead(buttonPin);
  // check if the button state has changed
  if (buttonState != lastButtonState) {
    // check if the pushbutton is NOT pressed
    if (buttonState == HIGH) {
      vannRennerFlagg = 0;                // nullstiller etter en lekkasje
      Serial.print("                Det renner ikke vann, sender verdi: ");
      Serial.println(vannRennerFlagg);
      client.loop();                                                   // MQTT loop
      String vannRennerTopic = "dam/vannRenner";
      snprintf(vannRennerMsg, 10, "%d"  , vannRennerFlagg);
      client.publish(vannRennerTopic.c_str(), vannRennerMsg);
      vannRennerFlagg = previousState;
      vannRennerFlagg++;
      previousState = vannRennerFlagg;
      Serial.print("                Det renner vann, sender verdi:      ");
    // update lastButtonState to the current buttonState
    lastButtonState = buttonState;
  delay(100); // small delay to debounce the button
// helper-functions
void PrintFileNameDateTime() {
  Serial.println( F("Code running comes from file: ") );
  Serial.println( F(__FILE__) );
  Serial.print( F("Compilert") );
  Serial.print( F(__DATE__) );
  Serial.print( F(" ") );
  Serial.println( F(__TIME__) );
this seems awkward that there are three tests for connected,
look at the example
