'MQTT' does not name a type; did you mean 'MQTT_H'?
Buena noche foro, estaba intentando utilizar el siguiente código, ya que empiezo a hacer practicas para entender como funciona arduino pero el siguiente código me da el siguiente error 'MQTT' does not name a type; did you mean 'MQTT_H'?
#include <MQTTClient.h>
#include <ESP8266WiFi.h>
#include <MQTT.h>
#include <EEPROM.h>
#define DEBUG
#define AP_SSID     "CLARO_2012E8"
#define AP_PASSWORD "5127F5BEE8"
#define EIOTCLOUD_USERNAME "edson rodas"
#define EIOTCLOUD_PASSWORD "Karina51985529"
// create MQTT object //
#define EIOT_CLOUD_ADDRESS "cloud.iot-playground.com"
#define PIN_PUMP         BUILTIN_LED //D0  // // nodemcu built in LED//
#define PIN_BUTTON       D3  // nodemcu flash button//
#define PIN_HUM_ANALOG   A0  // humidity pin//
#define MAX_ANALOG_VAL         956
#define MIN_ANALOG_VAL         250
#define IRRIGATION_TIME        10 // irrigation time in sec//
#define IRRIGATION_PAUSE_TIME  300 // irrigation pause time in sec - only for auto irrigator//
// irrigator state //
typedef enum {
  s_idle             = 0,  // irrigation idle//
  s_irrigation_start = 1,  // start irrigation//
  s_irrigation       = 2,  // irrigate//
  s_irrigation_stop  = 3,  // irrigation stop//
} e_state;
#define CONFIG_START 0
#define CONFIG_VERSION "v01"
struct StoreStruct {
  // This is for mere detection if they are your settings//
  char version[4];
  // The variables of your settings//
  uint moduleId;  // module id//
} storage = {
  CONFIG_VERSION,
  // The default module 0//
  0,
#define PARAM_HUMIDITY_TRESHOLD   "Sensor.Parameter1"
#define PARAM_MANUAL_AUTO_MODE    "Sensor.Parameter2"
#define PARAM_PUMP_ON             "Sensor.Parameter3"
#define PARAM_HUMIDITY            "Sensor.Parameter4"
#define MS_IN_SEC  1000; // 1S  //
MQTT myMqtt("", EIOT_CLOUD_ADDRESS, 1883);
// intvariables//
int state;
bool stepOk = false;
int soilHumidityThreshold;
bool autoMode;
String valueStr("");
String topic("");
boolean result;
int lastAnalogReading;
bool autoModeOld;
int soilHumidityThresholdOld;
unsigned long startTime;
int soilHum;
int irrigatorCounter;
  state = s_idle;
  pinMode(PIN_PUMP, OUTPUT);
  pinMode(PIN_BUTTON, INPUT);
  autoMode = false;
  stepOk = false;
  soilHumidityThresholdOld = -1;
  startTime = millis();
  soilHum = -1;
  WiFi.mode(WIFI_STA);
  WiFi.begin(AP_SSID, AP_PASSWORD);
  Serial.print("Connecting to ");
  Serial.println(AP_SSID);
    Serial.print(".");
No usado: C:\Users\EDSON\Documents\Arduino\libraries\MQTT_Client-1.0.2
exit status 1
Moderador:
Por favor, lee las Normas del foro y edita tu código/error usando etiquetas de código.
Ve a edición, luego selecciona todo el código que has publicado, lo cortas y click en </>
Tambíen retira el "Ayuda con.."
Mira el punto 5 de las normas de cómo se espera que sea un título.
EDITO:
Título editado
Código con etiquetas.
