I am running the code example in knolleary/pubsubclient/examples/mqtt_esp8266. The code is running great but I have a question: Where is the data for controlling the LED coming from??? Approximately every second, the LED is changing state, but nowhere in the code can I find what is sending this data. Thank you for any help.
// https://github.com/knolleary/pubsubclient/blob/master/examples/mqtt_esp8266/mqtt_esp8266.ino
Basic ESP8266 MQTT example
This sketch demonstrates the capabilities of the pubsub library in combination
with the ESP8266 board/library.
It connects to an MQTT server then:
- publishes "hello world" to the topic "outTopic" every xx seconds
- subscribes to the topic "inTopic", printing out any messages
it receives. NB - it assumes the received payloads are strings not binary
- If the first character of the topic "inTopic" is an 1, switch ON the ESP Led,
else switch it off
It will reconnect to the server if the connection is lost using a blocking
reconnect function. See the 'mqtt_reconnect_nonblocking' example for how to
achieve the same result without blocking the main loop.
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
WiFiClient mqttClient;
PubSubClient client(mqttClient);
unsigned long lastMsg = 0;
#define MSG_BUFFER_SIZE (50)
char msg[MSG_BUFFER_SIZE];
int msgNumber = 0;
const char* ssid = "xxx";
const char* password = "xxx";
//const char* mqtt_server = "broker.hivemq.com";
const char* mqtt_server = "broker.mqtt-dashboard.com";
void setup_wifi() {
int i = 0;
delay(10);
Serial.print("Connecting to ");// We start by connecting to a WiFi network
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
i++;
Serial.print(".");
Serial.println("WiFi connected");
Serial.print("Time=");
Serial.println(i / 2);
Serial.println("IP address: "); // 192.168.1.8
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) { // length = 1 always?
Serial.print((char)payload[i]);
if ((char)payload[0] == '1') { // on LED if 1 first character
digitalWrite(BUILTIN_LED, LOW); // LED on LOW is the voltage level
else digitalWrite(BUILTIN_LED, HIGH);// Turn the LED off
void reconnect() {
while (!client.connected()) { // Loop until we're reconnected
Serial.print("MQTT connection...");
String clientId = "stevensarns";
// clientId += String(random(0xffff), HEX); // Create a random client ID
if (client.connect(clientId.c_str())) { // Attempt to connect
Serial.println("connected");
client.publish("outTopic", "xxx"); // Once connected, publish
client.subscribe("inTopic"); // ... and resubscribe
else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
delay(5000); // Wait 5 seconds before retrying
pinMode(BUILTIN_LED, OUTPUT); // led output
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
if (!client.connected()) reconnect(); // always executes on first loop
client.loop(); // returns false of discon, true of connect
unsigned long now = millis();
if (now - lastMsg > 10000) {
lastMsg = now;
++msgNumber;
snprintf (msg, MSG_BUFFER_SIZE, "hello world #%ld", msgNumber);
Serial.print("Publish message: ");
Serial.println(msg);
client.publish("outTopic", msg);
