MQTT how to connect to SSL/TLS
Hi everyone,
I am using PubSubClient to connect to MQTT.
I registered in a cloud mqtt service to do my tests so to avoid errors due to possible miss configuration on personal server.
The server provider gives me 3 ports:
port...
ssl port...
websocket(TLS only)..
I was connecting to the regular port but it was unencrypted. Decided to switch to ssl port and the only change I made was to include the wifi secure instead of regular wifi(and obviously use the different port of the server) :
#include <WiFiClientSecure.h>
WiFiClientSecure wifiClient;
I can now connect to SSL port and receive data on the ESP32.
However when trying to publish from mosquitto_pub just by replacing the port with the ssl port i get error "Error: The connection was lost.".
How is it possible arduino(esp32) to connect to MQTT server on the SSL port without providing any cert files but mosquitto_pub not to connect?
What am I missing?
Also, how to connect to TLS and not to SSL with arduino?
Thank you!
How is it possible to help you debug conde without seeing the code to debug?
I do not have any code for MQTT that connects to TLS. Im looking for code such this so I can use it :slight_smile:
Im also trying to understand that the mqtt client(like pubsubclient) has to support TLS or the wifi client?
thank you
OK.
So read this thread called MQTT and TLS: Arduino Forum
You will be most interested in post #10
thanks for that, im trying to find on my mqtt server provider the files.
On their FAQ page:
Our server certificate is currently issued by Sectigo with USERTrust RSA Certification Authority as root.
If you don't have a trust store you can download the USERTrust RSA Certification Authority (SHA-2) root certificate from sectigo.com KB or via crt.sh.
On sectigo page which one is the CACert, Certificate and PrivateKey that i should use?
Thank you!
chris700:
On their FAQ page:
[color=#212529]Our server certificate is currently issued by Sectigo with USERTrust RSA Certification Authority as root.[/color]
If you don't have a trust store you can download the USERTrust RSA Certification Authority (SHA-2) root certificate from [iurl=Comodo Knowledge Base]sectigo.com KB [/iurl]or via [iurl=crt.sh | 1199354]crt.sh[/iurl].
On [sectigo](https://support.sectigo.com/articles/Knowledge/Sectigo-Intermediate-Certificates)[](https://support.sectigo.com/articles/Knowledge/Sectigo-Intermediate-Certificates) page which one is the CACert, Certificate and PrivateKey that i should use?
Thank you!
I'm not doing your research.
I just do not understand which files I need because on the link they have many
