MQTT Loop in the Loop section why?
Can someone explain a very simple question please?
Using the following MQTT example and this mqtt.loop is confusing me. In the code there is not mqtt.loop as a function? Why is it called if the code is in the loop section? Or does mqtt.loop just cycle every 30 secs?
  mqtt.loop();
 * For this example, you need to install PubSubClient library:
 *   https://github.com/knolleary/pubsubclient
 *   or from http://librarymanager/all#PubSubClient
 * TinyGSM Getting Started guide:
 *   https://tiny.cc/tinygsm-readme
 * For more MQTT examples, see PubSubClient library
 * This example connects to HiveMQ's showcase broker.
 * You can quickly test sending and receiving messages from the HiveMQ webclient
 * available at http://www.hivemq.com/demos/websocket-client/.
 * Subscribe to the topic GsmClientTest/ledStatus
 * Publish "toggle" to the topic GsmClientTest/led and the LED on your board
 * should toggle and you should see a new message published to
 * GsmClientTest/ledStatus with the newest LED status.
// Select your modem:
#define TINY_GSM_MODEM_SIM800
// #define TINY_GSM_MODEM_SIM808
// #define TINY_GSM_MODEM_SIM868
// #define TINY_GSM_MODEM_SIM900
// #define TINY_GSM_MODEM_SIM7000
// #define TINY_GSM_MODEM_SIM7000SSL
// #define TINY_GSM_MODEM_SIM7080
// #define TINY_GSM_MODEM_SIM5360
// #define TINY_GSM_MODEM_SIM7600
// #define TINY_GSM_MODEM_UBLOX
// #define TINY_GSM_MODEM_SARAR4
// #define TINY_GSM_MODEM_M95
// #define TINY_GSM_MODEM_BG96
// #define TINY_GSM_MODEM_A6
// #define TINY_GSM_MODEM_A7
// #define TINY_GSM_MODEM_M590
// #define TINY_GSM_MODEM_MC60
// #define TINY_GSM_MODEM_MC60E
// #define TINY_GSM_MODEM_ESP8266
// #define TINY_GSM_MODEM_XBEE
// #define TINY_GSM_MODEM_SEQUANS_MONARCH
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// Set serial for AT commands (to the module)
// Use Hardware Serial on Mega, Leonardo, Micro
#ifndef __AVR_ATmega328P__
#define SerialAT Serial1
// or Software Serial on Uno, Nano
#else
#include <SoftwareSerial.h>
SoftwareSerial SerialAT(2, 3);  // RX, TX
#endif
// See all AT commands, if wanted
// #define DUMP_AT_COMMANDS
// Define the serial console for debug prints, if needed
#define TINY_GSM_DEBUG SerialMon
// Range to attempt to autobaud
// NOTE:  DO NOT AUTOBAUD in production code.  Once you've established
// communication, set a fixed baud rate using modem.setBaud(#).
#define GSM_AUTOBAUD_MIN 9600
#define GSM_AUTOBAUD_MAX 115200
// Add a reception delay, if needed.
// This may be needed for a fast processor at a slow baud rate.
// #define TINY_GSM_YIELD() { delay(2); }
// Define how you're planning to connect to the internet.
// This is only needed for this example, not in other code.
#define TINY_GSM_USE_GPRS true
#define TINY_GSM_USE_WIFI false
// set GSM PIN, if any
#define GSM_PIN ""
// Your GPRS credentials, if any
const char apn[]      = "YourAPN";
const char gprsUser[] = "";
const char gprsPass[] = "";
// Your WiFi connection credentials, if applicable
const char wifiSSID[] = "YourSSID";
const char wifiPass[] = "YourWiFiPass";
// MQTT details
const char* broker = "broker.hivemq.com";
const char* topicLed       = "GsmClientTest/led";
const char* topicInit      = "GsmClientTest/init";
const char* topicLedStatus = "GsmClientTest/ledStatus";
#include <TinyGsmClient.h>
#include <PubSubClient.h>
// Just in case someone defined the wrong thing..
#if TINY_GSM_USE_GPRS && not defined TINY_GSM_MODEM_HAS_GPRS
#undef TINY_GSM_USE_GPRS
#undef TINY_GSM_USE_WIFI
#define TINY_GSM_USE_GPRS false
#define TINY_GSM_USE_WIFI true
#endif
#if TINY_GSM_USE_WIFI && not defined TINY_GSM_MODEM_HAS_WIFI
#endif
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SerialAT, SerialMon);
TinyGsm        modem(debugger);
#else
TinyGsm        modem(SerialAT);
#endif
TinyGsmClient client(modem);
PubSubClient  mqtt(client);
#define LED_PIN 13
int ledStatus = LOW;
uint32_t lastReconnectAttempt = 0;
void mqttCallback(char* topic, byte* payload, unsigned int len) {
  SerialMon.print("Message arrived [");
  SerialMon.print(topic);
  SerialMon.print("]: ");
  SerialMon.write(payload, len);
  SerialMon.println();
  // Only proceed if incoming message's topic matches
  if (String(topic) == topicLed) {
    ledStatus = !ledStatus;
    digitalWrite(LED_PIN, ledStatus);
    mqtt.publish(topicLedStatus, ledStatus ? "1" : "0");
boolean mqttConnect() {
  SerialMon.print("Connecting to ");
  SerialMon.print(broker);
  // Connect to MQTT Broker
  boolean status = mqtt.connect("GsmClientTest");
  // Or, if you want to authenticate MQTT:
  // boolean status = mqtt.connect("GsmClientName", "mqtt_user", "mqtt_pass");
  if (status == false) {
    SerialMon.println(" fail");
    return false;
  SerialMon.println(" success");
  mqtt.publish(topicInit, "GsmClientTest started");
  mqtt.subscribe(topicLed);
  return mqtt.connected();
  // Set console baud rate
  SerialMon.begin(115200);
  delay(10);
  pinMode(LED_PIN, OUTPUT);
  // Set your reset, enable, power pins here
  SerialMon.println("Wait...");
  // Set GSM module baud rate
  TinyGsmAutoBaud(SerialAT, GSM_AUTOBAUD_MIN, GSM_AUTOBAUD_MAX);
  // SerialAT.begin(9600);
  delay(6000);
  // Restart takes quite some time
  // To skip it, call init() instead of restart()
  SerialMon.println("Initializing modem...");
  modem.restart();
  // modem.init();
  String modemInfo = modem.getModemInfo();
  SerialMon.print("Modem Info: ");
  SerialMon.println(modemInfo);
  // Unlock your SIM card with a PIN if needed
  if (GSM_PIN && modem.getSimStatus() != 3) { modem.simUnlock(GSM_PIN); }
#endif
  // Wifi connection parameters must be set before waiting for the network
  SerialMon.print(F("Setting SSID/password..."));
  if (!modem.networkConnect(wifiSSID, wifiPass)) {
    delay(10000);
    return;
#endif
#if TINY_GSM_USE_GPRS && defined TINY_GSM_MODEM_XBEE
  // The XBee must run the gprsConnect function BEFORE waiting for network!
  modem.gprsConnect(apn, gprsUser, gprsPass);
#endif
  SerialMon.print("Waiting for network...");
  if (!modem.waitForNetwork()) {
    delay(10000);
    return;
  if (modem.isNetworkConnected()) { SerialMon.println("Network connected"); }
  // GPRS connection parameters are usually set after network registration
  SerialMon.print(F("Connecting to "));
  SerialMon.print(apn);
  if (!modem.gprsConnect(apn, gprsUser, gprsPass)) {
    delay(10000);
    return;
  if (modem.isGprsConnected()) { SerialMon.println("GPRS connected"); }
#endif
  // MQTT Broker setup
  mqtt.setServer(broker, 1883);
  mqtt.setCallback(mqttCallback);
  // Make sure we're still registered on the network
  if (!modem.isNetworkConnected()) {
    SerialMon.println("Network disconnected");
    if (!modem.waitForNetwork(180000L, true)) {
      delay(10000);
      return;
      SerialMon.println("Network re-connected");
    // and make sure GPRS/EPS is still connected
    if (!modem.isGprsConnected()) {
      SerialMon.println("GPRS disconnected!");
        delay(10000);
        return;
      if (modem.isGprsConnected()) { SerialMon.println("GPRS reconnected"); }
#endif
  if (!mqtt.connected()) {
    SerialMon.println("=== MQTT NOT CONNECTED ===");
    // Reconnect every 10 seconds
    uint32_t t = millis();
    if (t - lastReconnectAttempt > 10000L) {
      lastReconnectAttempt = t;
      if (mqttConnect()) { lastReconnectAttempt = 0; }
    delay(100);
    return;
  mqtt.loop();
mqtt.loop() is the function in the PubSubClient library that checks for new messages. It is wise to call it frequently, hence it is called from loop()
Where did you get the figure of 30 seconds from ?
Thanks I checked for the mqtt.loop GitHub - knolleary/pubsubclient: A client library for the Arduino Ethernet Shield that provides support for MQTT. and also C:\Users\username\Documents\Arduino\libraries\pubsubclient-master? Not sure on the 30secs but keen to understand when it loops?
Which file is it located in out of interest please?
Is this the mqtt.loop? C:\Users\username\Documents\Arduino\libraries\pubsubclient-master\src\PubSubClient.cpp
boolean PubSubClient::loop() {
    if (connected()) {
        unsigned long t = millis();
        if ((t - lastInActivity > this->keepAlive*1000UL) || (t - lastOutActivity > this->keepAlive*1000UL)) {
            if (pingOutstanding) {
                this->_state = MQTT_CONNECTION_TIMEOUT;
                _client->stop();
                return false;
                this->buffer[0] = MQTTPINGREQ;
                this->buffer[1] = 0;
                _client->write(this->buffer,2);
                lastOutActivity = t;
                lastInActivity = t;
                pingOutstanding = true;
        if (_client->available()) {
            uint8_t llen;
            uint16_t len = readPacket(&llen);
            uint16_t msgId = 0;
            uint8_t *payload;
            if (len > 0) {
                lastInActivity = t;
                uint8_t type = this->buffer[0]&0xF0;
                if (type == MQTTPUBLISH) {
                    if (callback) {
                        uint16_t tl = (this->buffer[llen+1]<<8)+this->buffer[llen+2]; /* topic length in bytes */
                        memmove(this->buffer+llen+2,this->buffer+llen+3,tl); /* move topic inside buffer 1 byte to front */
                        this->buffer[llen+2+tl] = 0; /* end the topic as a 'C' string with \x00 */
                        char *topic = (char*) this->buffer+llen+2;
                        // msgId only present for QOS>0
                        if ((this->buffer[0]&0x06) == MQTTQOS1) {
                            msgId = (this->buffer[llen+3+tl]<<8)+this->buffer[llen+3+tl+1];
                            payload = this->buffer+llen+3+tl+2;
                            callback(topic,payload,len-llen-3-tl-2);
                            this->buffer[0] = MQTTPUBACK;
                            this->buffer[1] = 2;
                            this->buffer[2] = (msgId >> 8);
                            this->buffer[3] = (msgId & 0xFF);
                            _client->write(this->buffer,4);
                            payload = this->buffer+llen+3+tl;
                            callback(topic,payload,len-llen-3-tl);
                } else if (type == MQTTPINGREQ) {
                    this->buffer[0] = MQTTPINGRESP;
                } else if (type == MQTTPINGRESP) {
                    pingOutstanding = false;
            } else if (!connected()) {
                // readPacket has closed the connection
                return false;
        return true;
    return false;
Yes
It might have been better if the library author had given the function a different name because it does not loop
Thanks and yes its confusing
Indeeed. poll(), update(), check() or refresh() would have been clearer about the role of this function.
