MQTT+Mega+CC3000
Hi!
I have the following code that I would like to use with my Mega and a CC3000 wifi shield to transmit MQTT messages.
The problem is that my MQTT client cannot connect with the server. I have a broker running in my computer(server) and I have tested it and it works fine - sending and receiving messages. The problem appears after Im connected with my server, I am not able to receive any messages in the Subscription Topic.
if (!client.connected()) {
client = cc3000.connectTCP(server.ip, 1883);
Serial.println("Server connected");
if(client.connected()) {
if (mqttclient.connect("home")) {
mqttclient.publish("home","home");
Serial.println("Home connected");
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <PubSubClient.h>
#define aref_voltage 3.3
#define ADAFRUIT_CC3000_IRQ   3  // MUST be an interrupt pin!
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT, SPI_CLOCK_DIVIDER);
#define WLAN_SSID       "xxxxxxxxxx"
#define WLAN_PASS       "xxxxxxxxxx"
#define WLAN_SECURITY   WLAN_SEC_WPA2
Adafruit_CC3000_Client client;
//TMP36
int tempPin = 1;
int tempReading;
// We're going to set our broker IP and union it to something we can use
union ArrayToIp {
  byte array[4];
  uint32_t ip;
ArrayToIp server = {
  192,168,2,101 };
PubSubClient mqttclient(server.ip, 1883, callback, client, cc3000);
void callback (char* topic, byte* payload, unsigned int length) {
void setup(void)
  Serial.println(F("Hello, CC3000!\n"));
  analogReference(EXTERNAL);
  Serial.println(F("\nInitialising the CC3000 ..."));
  if (!cc3000.begin()) {
    Serial.println(F("Unable to initialise the CC3000! Check your wiring?"));
    for(;;);
  Serial.println(F("\nDeleting old connection profiles"));
  if (!cc3000.deleteProfiles()) {
    Serial.println(F("Failed!"));
    while(1);
  /* Attempt to connect to an access point */
  char *ssid = WLAN_SSID;             /* Max 32 chars */
  Serial.print(F("\nAttempting to connect to "));
  Serial.println(ssid);
  /* NOTE: Secure connections are not available in 'Tiny' mode! */
  if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
    while(1);
  Serial.println(F("Connected!"));
  /* Wait for DHCP to complete */
  Serial.println(F("Request DHCP"));
  while (!cc3000.checkDHCP()) {
    delay(100); // ToDo: Insert a DHCP timeout!
  // connect to the broker
  // did that last thing work? sweet, let's do something
void loop(void) {
  float temperatureReading = analogRead(tempPin);
  float voltage = temperatureReading * aref_voltage;
  voltage /= 1024.0;
  float temperatureC = (voltage - 0.5) * 100 ;
  float temperatureF = (temperatureC * 9.0 / 5.0) + 32.0;
  // cheap tricks I tell you
  char stringTemperatureF[10];
  dtostrf(temperatureF, 0, 3, stringTemperatureF);
  // are we still connected?
      if (mqttclient.connect("client")) {
  else {
    // yep, publish that test
    mqttclient.publish("home", stringTemperatureF);
  Serial.println(stringTemperatureF);
  delay(5000);
EDIT
Code works fine. Tested it with another WiFi shield. Obviously the one before was faulty and can't connect.
