Mqtt Opentherm controller
I'm using the code below to control my central heating system.
Everything works fine, except the fact that the hot water production is allways on.
Could anyone help me adapting the code so I can switch on and off the hot water production over mqtt.
  This example runs directly on ESP8266 chip.
  Please be sure to select the right ESP8266 module
  in the Tools -> Board -> WeMos D1 Mini
  Adjust settings in Config.h before run
#include <ESP8266WiFi.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <PubSubClient.h>
#include <OpenTherm.h>
// Your WiFi credentials.
// Set password to "" for open networks.
const char* ssid = "YOUR_WIFI";
const char* pass = "YOUR_PASSWORD";
// Your MQTT broker address and credentials
const char* mqtt_server = "xxx.xxx.xxx.xxx";
const char* mqtt_user = "mqtt_user";
const char* mqtt_password = "mqtt_password";
const int mqtt_port = 1883;
// Master OpenTherm Shield pins configuration
const int OT_IN_PIN = 4;  //for Arduino, 4 for ESP8266 (D2), 21 for ESP32
const int OT_OUT_PIN = 5; //for Arduino, 5 for ESP8266 (D1), 22 for ESP32
// Temperature sensor pin
const int ROOM_TEMP_SENSOR_PIN = 14; //for Arduino, 14 for ESP8266 (D5), 18 for ESP32
// MQTT topics
const char* CURRENT_TEMP_GET_TOPIC = "opentherm-thermostat/current-temperature/get";
const char* CURRENT_TEMP_SET_TOPIC = "opentherm-thermostat/current-temperature/set";
const char* TEMP_SETPOINT_GET_TOPIC = "opentherm-thermostat/setpoint-temperature/get";
const char* TEMP_SETPOINT_SET_TOPIC = "opentherm-thermostat/setpoint-temperature/set";
const char* MODE_GET_TOPIC = "opentherm-thermostat/mode/get";
const char* MODE_SET_TOPIC = "opentherm-thermostat/mode/set";
const char* TEMP_BOILER_GET_TOPIC = "opentherm-thermostat/boiler-temperature/get";
const char* TEMP_BOILER_TARGET_GET_TOPIC = "opentherm-thermostat/boiler-target-temperature/get";
const unsigned long extTempTimeout_ms = 60 * 1000;
const unsigned long statusUpdateInterval_ms = 1000;
float  sp = 15, //set point
       t = 15, //current temperature
       t_last = 0, //prior temperature
       ierr = 25, //integral error
       dt = 0, //time between measurements
       op = 0; //PID controller output
unsigned long ts = 0, new_ts = 0; //timestamp
unsigned long lastUpdate = 0;
unsigned long lastTempSet = 0;
bool heatingEnabled = true;
#define MSG_BUFFER_SIZE  (50)
char msg[MSG_BUFFER_SIZE];
OneWire oneWire(ROOM_TEMP_SENSOR_PIN);
DallasTemperature sensors(&oneWire);
OpenTherm ot(OT_IN_PIN, OT_OUT_PIN);
WiFiClient espClient;
PubSubClient client(espClient);
void ICACHE_RAM_ATTR handleInterrupt() {
  ot.handleInterrupt();
float getTemp() {
  unsigned long now = millis();
  if (now - lastTempSet > extTempTimeout_ms)
    return sensors.getTempCByIndex(0);
    return t;
float pid(float sp, float pv, float pv_last, float& ierr, float dt) {
  float KP = 10;
  float KI = 0.02;
  // upper and lower bounds on heater level
  float ophi = 63;
  float oplo = 20;
  // calculate the error
  float error = sp - pv;
  // calculate the integral error
  ierr = ierr + KI * error * dt;
  // calculate the measurement derivative
  //float dpv = (pv - pv_last) / dt;
  // calculate the PID output
  float P = KP * error; //proportional contribution
  float I = ierr; //integral contribution
  float op = P + I;
  // implement anti-reset windup
  if ((op < oplo) || (op > ophi)) {
    I = I - KI * error * dt;
    // clip output
    op = max(oplo, min(ophi, op));
  ierr = I;
  Serial.println("sp=" + String(sp) + " pv=" + String(pv) + " dt=" + String(dt) + " op=" + String(op) + " P=" + String(P) + " I=" + String(I));
  return op;
// This function calculates temperature and sends data to MQTT every second.
void updateData()
  //Set/Get Boiler Status
  bool enableHotWater = true;
  bool enableCooling = false;
  unsigned long response = ot.setBoilerStatus(heatingEnabled, enableHotWater, enableCooling);
  OpenThermResponseStatus responseStatus = ot.getLastResponseStatus();
  if (responseStatus != OpenThermResponseStatus::SUCCESS) {
    Serial.println("Error: Invalid boiler response " + String(response, HEX));
  t = getTemp();
  new_ts = millis();
  dt = (new_ts - ts) / 1000.0;
  ts = new_ts;
  if (responseStatus == OpenThermResponseStatus::SUCCESS) {
    op = pid(sp, t, t_last, ierr, dt);
    ot.setBoilerTemperature(op);
  t_last = t;
  sensors.requestTemperatures(); //async temperature request
  snprintf (msg, MSG_BUFFER_SIZE, "%s", String(op).c_str());
  client.publish(TEMP_BOILER_TARGET_GET_TOPIC, msg);
  snprintf (msg, MSG_BUFFER_SIZE, "%s", String(t).c_str());
  client.publish(CURRENT_TEMP_GET_TOPIC, msg);
  float bt = ot.getBoilerTemperature();
  snprintf (msg, MSG_BUFFER_SIZE, "%s", String(bt).c_str());
  client.publish(TEMP_BOILER_GET_TOPIC, msg);
  snprintf (msg, MSG_BUFFER_SIZE, "%s", String(sp).c_str());
  client.publish(TEMP_SETPOINT_GET_TOPIC, msg);
  snprintf (msg, MSG_BUFFER_SIZE, "%s", heatingEnabled ? "heat" : "off");
  client.publish(MODE_GET_TOPIC, msg);
  Serial.print("Current temperature: " + String(t) + " °C ");
  String tempSource = (millis() - lastTempSet > extTempTimeout_ms)
                      ? "(internal sensor)"
                      : "(external sensor)";
  Serial.println(tempSource);
String convertPayloadToStr(byte* payload, unsigned int length) {
  char s[length + 1];
  s[length] = 0;
  for (int i = 0; i < length; ++i)
    s[i] = payload[i];
  String tempRequestStr(s);
  return tempRequestStr;
const String setpointSetTopic(TEMP_SETPOINT_SET_TOPIC);
const String currentTempSetTopic(CURRENT_TEMP_SET_TOPIC);
const String modeSetTopic(MODE_SET_TOPIC);
void callback(char* topic, byte* payload, unsigned int length) {
  const String topicStr(topic);
  String payloadStr = convertPayloadToStr(payload, length);
  if (topicStr == setpointSetTopic) {
    Serial.println("Set target temperature: " + payloadStr);
    sp = payloadStr.toFloat();
  else if (topicStr == currentTempSetTopic) {
    t = payloadStr.toFloat();
    lastTempSet = millis();
  else if (topicStr == modeSetTopic) {
    Serial.println("Set mode: " + payloadStr);
    if (payloadStr == "heat")
    else if (payloadStr == "off")
      heatingEnabled = false;
      Serial.println("Unknown mode");
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    const char* clientId = "opentherm-thermostat-test";
    if (client.connect(clientId, mqtt_user, mqtt_password)) {
      Serial.println("ok");
      client.subscribe(TEMP_SETPOINT_SET_TOPIC);
      client.subscribe(MODE_SET_TOPIC);
      client.subscribe(CURRENT_TEMP_SET_TOPIC);
      Serial.print(" failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
  Serial.println("Connecting to " + String(ssid));
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, pass);
  int deadCounter = 20;
  while (WiFi.status() != WL_CONNECTED && deadCounter-- > 0) {
    Serial.print(".");
  if (WiFi.status() != WL_CONNECTED) {
    Serial.println("Failed to connect to " + String(ssid));
    while (true);
  else {
  client.setServer(mqtt_server, mqtt_port);
  client.setCallback(callback);
  ot.begin(handleInterrupt);
  //Init DS18B20 sensor
  sensors.begin();
  sensors.setWaitForConversion(false); //switch to async mode
  t, t_last = sensors.getTempCByIndex(0);
  ts = millis();
  lastTempSet = -extTempTimeout_ms;
  if (!client.connected()) {
    reconnect();
  client.loop();
  if (now - lastUpdate > statusUpdateInterval_ms) {
    lastUpdate = now;
    updateData();
Hot water appears to be controlled by your enableHotWater variable, which never changes.
It looks like you need another MQTT topic like the one that controls the boiler using heatingEnabled. Or you could extend that one to have four modes: all off, heat only, water only, heat and water.
indeed the enableHotWater is allways set on true.
I lack the knowledge of mqtt, enableHotWater is this a boolean? how should I control this?
bool means boolean.
How do you control it now? What sends the MQTT messages?
with home assistant, explanation is found here:
https://diyless.com/blog/home-assistant-opentherm-thermostat
I was not sure if it is controlled by a bool or a string containing "true" or "false" on the side of mqtt
It looks like most of the work is configuring Home Assistant. Does it know about your water heater and have something to control it in the GUI?
I'll guess that the water heater has its own thermostat and that you don't need to set it, just control whether it is on or off. Is that right?
Either way, it looks like the first thing to do is to change the config yaml file, and when that's working, change the Arduino code. This probably isn't the best place to be asking about the former.
the home assistant part is easy, I just don't know arduino code enough to change the arduino part
I suggest then that you make the changes you can and then specify the MQTT topics you've created and what they send. Only then can the Arduino code be tweaked.
I would think that other folks have already done this - you may be able to find the code already done somewhere.
Where did you get the MQTT topic information?
If you have no topic for power or something similar, you could just set the heat to 0°C. It will never come on.
