MQTT problem
Hi! I use an Arduino mega with w5500 eth shield. I wrote this code to receive mqtt messages from openhab. The MQTT and the openhab works well but when i send an on command to this topic the output simply switch up and then down. for the off command the same thing happens. then i realized that it doesn't matter which topic receive the message the pin goes up and down when an mqtt messega received. What did I wrote wrong?
#include <SPI.h>
#include <Ethernet2.h>
#include <PubSubClient.h>
#include <Wire.h>
unsigned long interval=5000;  // the time we need to wait
unsigned long previousMillis=0; // millis() returns an unsigned long.
int erkl = 13;
// Update these with values suitable for your network.
byte mac[]    = {  0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
byte server[] = { 172, 16, 10, 105 };
byte ip[]     = { 172, 16, 10, 214 };
void callback(char* topic, byte* payload, unsigned int length);
EthernetClient ethClient;
PubSubClient client(server, 1883, callback, ethClient);
  pinMode(13, OUTPUT);
  Ethernet.begin(mac, ip);
  if (client.connect("arduinoClient")) {
    client.publish("outTopic","hello world");
    client.subscribe("/mega/#");
  client.loop();
void callback(char* topic, byte* payload, unsigned int length) {
char receivedChar;
Serial.println("Callback");
Serial.print("Topic ");
Serial.println(topic);
Serial.print("Length ");
Serial.println(length);
Serial.print("Payload ");
for (int i=0;i<length;i++) {
receivedChar = (char)payload[i];
Serial.print(receivedChar);}
  if (topic == "/mega/erkl/1/com") {
   if (payload[0] == '0')
    digitalWrite(erkl, LOW);
    //delay(100);
    //client.publish("/mega/erkl/1/state","0");
    else if (payload[0] == '1')
    digitalWrite(erkl, HIGH);
    //delay(100);
    //client.publish("/mega/erkl/1/state","1");
if (receivedChar == '0')
    delay(100);
if (receivedChar == '1')
    delay(100);
Can you please fix you indentation? This is terrible to read.
I think this compares the address of topic to the string literal. To compare the content of char arrays, use strcmp. Not that strcmp return 0 if the strings are EQUAL.
Is it intended that you compare the last character of the payload? Also, why to you repeat this? Why do you need that and
You probably should strcmp the whole payload, if it is not explicitly desired to look at only the first and last char.
If I understand your problem correctly, I don't see any reason for that behavior, though.
Fix or comment on what I wrote above, add function for switching the pin on an off with debug output (don't touch the pin anywhere else), then post the new code and the serial output.
