MQTT publish stops loop
Hey, Im trying to make a thermostat using Arduino Mega2560, rotary encoder KY40 and temperature sensor ds18b20 and ethernet module ENC28J60. Everything work just fine until I try to publish temperature in a loop. Here is my code:
#include <OneWire.h>
#include <DallasTemperature.h>
#include <UIPEthernet.h>
#include <PubSubClient.h>
#include "config.h"
  pinMode(pinA, INPUT_PULLUP); // enabling pullups
  pinMode(pinB, INPUT_PULLUP);
  pinMode(pinSW, INPUT_PULLUP);
  // encoder pin on interrupt 0 (pin 2)
  attachInterrupt(0, doEncoderA, CHANGE);
  // encoder pin on interrupt 1 (pin 3)
  attachInterrupt(1, doEncoderB, CHANGE);
  sensors.begin();
  sensors.setResolution(thermometer, 9);
  mqttClient.setServer("test.mosquitto.org", 1883);
  mqttClient.setCallback(callback);
  connectToEthernet();
  delay(1500);
// main loop, work is done by interrupt service routines, this one only prints stuff
  if (!mqttClient.connected()) {
    reconnect();
  rotating = true;  // reset the debouncer
  //to protect from going over min & max values
  if (encoderPos <= MIN_POS - 1 ) {
    encoderPos = MIN_POS;
    lastReportedPos = MIN_POS + 1;
  } else if (encoderPos >= MAX_POS + 1) {
    encoderPos = MAX_POS;
    lastReportedPos = MAX_POS - 1;
    if (lastReportedPos != encoderPos) { // Serial print
      setTemp = encoderPos * 0.5;
      Serial.print("Set temperature: ");
      Serial.println(setTemp);
      lastReportedPos = encoderPos;
  if (digitalRead(pinSW) == LOW )  { // push to restart to 0
    encoderPos = 0;
    lastReportedPos = 1;
    delay (10);
  if (currentMillis - previousMillis >= interval) {
    //request temperature from sensors
    sensors.requestTemperatures();
    //print temperature out with my function
    printTemperature(thermometer);
  mqttClient.loop();
// Interrupt on A changing state
void doEncoderA() {
  if ( rotating ) delay (1);  // wait a little until the bouncing is done
  // Test transition, did things really change?
  if ( digitalRead(pinA) != A_set ) { // debounce once more
    A_set = !A_set;
    // adjust counter + if A leads B
    if ( A_set && !B_set ) encoderPos += 1;
    rotating = false;  // no more debouncing until loop() hits again
// Interrupt on B changing state, same as A above
void doEncoderB() {
  if ( digitalRead(pinB) != B_set ) {
    B_set = !B_set;
    //  adjust counter - 1 if B leads A
    if ( B_set && !A_set ) encoderPos -= 1;
    rotating = false;
// function to print the temperature for a device
void printTemperature(DeviceAddress deviceAddress) {
  float temperature = sensors.getTempC(deviceAddress);
  Serial.print("Got temperature: ");
  //Serial.println(temperature);
  char tempBuff[10];
  dtostrf(temperature, 3, 2, tempBuff);
  Serial.println(tempBuff);
  mqttClient.publish("temperature", tempBuff);
  Serial.println("published");
void connectToEthernet() {
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for (;;)
  // print your local IP address:
  Serial.print("My IP address: ");
  for (byte thisByte = 0; thisByte < 4; thisByte++) {
    // print the value of each byte of the IP address:
    Serial.print(Ethernet.localIP()[thisByte], DEC);
    Serial.print(".");
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
void reconnect() {
  // Loop until we're reconnected
  while (!mqttClient.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (mqttClient.connect("arduinoClient")) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      mqttClient.publish("outTopic", "hello world");
      // ... and resubscribe
      mqttClient.subscribe("inTopic");
      Serial.print("failed, rc=");
      Serial.print(mqttClient.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
and a config.h:
/*KY-40 INIT*/
#define MAX_POS 60
#define MIN_POS 30
enum PinAssignments {
  pinA = 2,   // DT pin
  pinB = 3,   // CLK pin
  pinSW = 4    // SW pin
volatile  int encoderPos = MIN_POS;  // a counter for the dial
int lastReportedPos = MIN_POS-1;   // change management
static boolean rotating = false;      // debounce management
// interrupt service routine vars
boolean A_set = false;
boolean B_set = false;
/*TEMP setup*/
float setTemp = MIN_POS*0.5;
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 5
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device address
DeviceAddress thermometer = { 0x28, 0xFF, 0xE3, 0xD4, 0x67, 0x14, 0x03, 0x39 };
/*DELAYS*/
unsigned long previousMillis = 0;
const long interval = 3000;
/*Ethernet*/
byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
EthernetClient ethClient;
/* MQTT */
PubSubClient mqttClient(ethClient);
char* tempC;
unsigned long time;
char message_buffer[100];[/quote]
The serial monitor shows this:
[quote]My IP address: 192.168.0.29.
Attempting MQTT connection...connected
Set temperature: 15.00
Got temperature: 25.00
published
and it stops... If I rotate encoder, nothing happens,it just publishes first value and then the loop stops. If I disable the line mqttClient.publish("temperature", tempBuff); it works againg, but of course it doesnt publish anything...
Any suggestions? Thanks in advance
P.S.: Dont mind some of the comments, I havent cleaned the sketch yet.
Good try on the tags - but you want code tags </> vs quote tags.
