MQTT (PubSubClient) - Crashing Arduino Mega2560
Hey All,
As per the topic name I am struggling with the PubSub client crashing when I receive a flood of MQTT messages.
If I send a message with a velocity of more than 1 second it hangs the device, I moved to MQTT thinking I could retire my own homebrew HTTP interface which hasn’t missed a beat in years but this a real struggle at the moment.
On the publisher side I tried QOS 1 and QOS 2 but it hasn’t helped. I saw a thread about the standard MQTT library being prone to crashes and to use an Adafruit library.
Below is my callback function and I wonder if I am doing something to cause this such as converting char’s to strings and so on.
Any help is appreciated.
//MQTT callback
    void callback(char* topic, byte* payload, unsigned int length) {
      IPAddress MQTTserver(10, 0, 0, 200);
      EthernetClient ethClient2;
      PubSubClient client2(ethClient2);
      client2.setServer(MQTTserver, 1883);
      Serial.println("MQTT message arrived");
      MQTTTopic = String(topic);
      MQTTPayload = "";
      Serial.println("MQTT topic is [" + MQTTTopic +"]");
      // ROLLER 1 SHUTTER
      if (MQTTTopic.indexOf("Roller_1") > 0) {
        for (int i=0;i<length;i++) {
          MQTTPayload = String(MQTTPayload + (char)payload[i]);
          Serial.println("MQTT payload is [" + MQTTPayload + "]");
        if (MQTTPayload == "on") {
          digitalWrite(RELAY_CH9, HIGH);
          digitalWrite(RELAY_CH9, LOW);
          Serial.println("Toggling - Roller Shutter 1 - UP -  1000msec");
          Serial.println("Toggle Relay 9 High");
          Serial.println("Toggle Relay 9 Low");
          //MQTT PUBLISH AN UPDATE BACK
          while (!client2.connected()) {
            // Attempt to connect
            if (client2.connect("arduinoClient")) {
               // Once connected, publish an announcement...
               client2.publish("stat/ARDUINO_Roller_1/POWER","on");
               Serial.println("Publishing stat/ARDUINO_Roller_1/POWER/on");
        if (MQTTPayload == "off") {
          digitalWrite(RELAY_CH10, HIGH);
          digitalWrite(RELAY_CH10, LOW);
          Serial.println("Toggling - Roller Shutter 1 - DOWN -  1000msec");
          Serial.println("Toggle Relay 10 High");
          Serial.println("Toggle Relay 10 Low");
               client2.publish("stat/ARDUINO_Roller_1/POWER","off");
               Serial.println("Publishing stat/ARDUINO_Roller_1/POWER/off,");
      // ROLLER 2 SHUTTER
      if (MQTTTopic.indexOf("Roller_2") > 0) {
          digitalWrite(RELAY_CH11, HIGH);
          digitalWrite(RELAY_CH11, LOW);
          Serial.println("Toggling - Roller Shutter 2 - UP -  1000msec");
          Serial.println("Toggle Relay 11 High");
          Serial.println("Toggle Relay 11 Low");
               client2.publish("stat/ARDUINO_Roller_2/POWER","on");
               Serial.println("Publishing stat/ARDUINO_Roller_2/POWER/on");
          digitalWrite(RELAY_CH12, HIGH);
          digitalWrite(RELAY_CH12, LOW);
          Serial.println("Toggling - Roller Shutter 2 - DOWN -  1000msec");
          Serial.println("Toggle Relay 12 High");
          Serial.println("Toggle Relay 12 Low");
               client2.publish("stat/ARDUINO_Roller_2/POWER","off");
               Serial.println("Publishing stat/ARDUINO_Roller_2/POWER/off");
      // ROLLER 3 SHUTTER
      if (MQTTTopic.indexOf("Roller_3") > 0) {
          digitalWrite(RELAY_CH13, HIGH);
          digitalWrite(RELAY_CH13, LOW);
          Serial.println("Toggling - Roller Shutter 4 - UP -  1000msec");
          Serial.println("Toggle Relay 13 High");
          Serial.println("Toggle Relay 13 Low");
               client2.publish("stat/ARDUINO_Roller_3/POWER","on");
               Serial.println("Publishing stat/ARDUINO_Roller_3/POWER/on");
          digitalWrite(RELAY_CH14, HIGH);
          digitalWrite(RELAY_CH14, LOW);
          Serial.println("Toggling - Roller Shutter 4 - DOWN -  1000msec");
          Serial.println("Toggle Relay 14 High");
          Serial.println("Toggle Relay 14 Low");
               client2.publish("stat/ARDUINO_Roller_3/POWER","off");
               Serial.println("Publishing stat/ARDUINO_Roller_3/POWER/off");
      // ROLLER 4 SHUTTER
      if (MQTTTopic.indexOf("Roller_4") > 0) {
          digitalWrite(RELAY_CH15, HIGH);
          digitalWrite(RELAY_CH15, LOW);
          Serial.println("Toggle Relay 15 High");
          Serial.println("Toggle Relay 15 Low");
               client2.publish("stat/ARDUINO_Roller_4/POWER","on");
               Serial.println("Publishing stat/ARDUINO_Roller_4/POWER/on");
          digitalWrite(RELAY_CH16, HIGH);
          digitalWrite(RELAY_CH16, LOW);
          Serial.println("Toggle Relay 16 High");
          Serial.println("Toggle Relay 16 Low");
               client2.publish("stat/ARDUINO_Roller_4/POWER","off");
               Serial.println("Publishing stat/ARDUINO_Roller_4/POWER/off");
Look at some examples of MQTT callbacks. Yours looks unusual, I wouldn't expect to see a new client being declared there.
Ok. So you want to process that much code , with serial prints, with a Mega in the callback function. Nope. Not, going to work.
PubSubClient does not do QOS2.
Oi! delay(1000); in a callback function and your complaint is you cannot process messages faster then 1 time a second when your callback function is sleeping for 1 second, in the least. Your callback has 6000 milliseconds of delay.
Many rules for a callback function are broken with your code.
PubSubClient works great and lasts a long time.
A MQTT callback
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  xSemaphoreTake( sema_MQTT_Parser, portMAX_DELAY);
  str_eTopic = topic;
  int i = 0;
  for ( i; i < length; i++)
    strPayload[i] = ((char)payload[i]);
  strPayload[i] = NULL;
  //log_i( "topic %s payload %s" ,str_eTopicPtr, strPayloadPtr );
  xSemaphoreGive ( sema_MQTT_Parser );
  xEventGroupSetBits( eg, evtParseMQTT ); // trigger tasks
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
that I use. its simple and dose nothing bet get the publication and topic, put it somewhere and signal the parser to do the thing.
void fparseMQTT( void *pvParameters )
  for (;;)
    xEventGroupWaitBits (eg, evtParseMQTT, pdTRUE, pdTRUE, portMAX_DELAY ); //
    xSemaphoreTake( sema_mqttOK, portMAX_DELAY );
    mqttOK = 0;
    xSemaphoreGive( sema_mqttOK );
    xSemaphoreTake( sema_MQTT_Parser, portMAX_DELAY );
    if ( str_eTopic == topicOutsideTemperature )
      oTemperature = String(strPayload).toFloat();
    if ( (String)str_eTopic == topicOutsideHumidity )
      oHumidity = String(strPayload).toFloat();
    if ( (String)str_eTopic == topicAQIndex )
      oIAQ = String(strPayload).toFloat();
    if ( String(str_eTopic) == topicOutsidePressure )
      oPressure = String(strPayload).toFloat();
    // clear pointer locations
    memset( strPayload, '\0', 300 );
    str_eTopic = ""; //clear string buffer
    xSemaphoreGive( sema_MQTT_Parser );
} // void fparseMQTT( void *pvParameters )
^^^^Parsing code.
DO NOT DO SERIAL PRINTS IN A CALLBACK.
DO NOT USE DELAY’s IN A CALLBACK.
DO NOT PUT A LOT OF CODE IN A CALLBACK.
The MCU that code comes from process 11 MQTT publications per second.
All,
I refactored my code to be non blocking. Your points are understood crystal clear.
Thanks
