Hi!
I'm trying to use MQTT to send 2 states, when there is activity from a PIR (my front door) and then after one minute I'm trying to send a message to tell that nobody is at the front door, so far I'm successful to send the message that the PIR had triggered but then after that the other message can't be broadcast...here is my code
Any cue would be really appreciated... I've tryed a bunch of things and I can't figure it out...
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// Hardware Definitions //
#define PIR_DOUT 4 // PIR digital output on D2
#define LED_PIN 5 // LED to illuminate on motion
#define RELAY_PIN_1 13 //pin for relay #1 (Smoke Machine)
#define PRINT_TIME 100 // Rate of serial printouts
unsigned long lastPrint = 0; // Keep track of last serial out
boolean trigger = false; // boolean to keep trigger
//MQTT settings
char message_buff[100];
int motionStatus = 0;
char* presence[]={"nobody...","Halloween!"};
const char *ssid = "my network"; // cannot be longer than 32 characters!
const char *pass = "my password";
// Update these with values suitable for your network.
IPAddress server(10, 0, 1, 101);
WiFiClient wclient;
PubSubClient client(wclient, server);
// Callback function
void callback(const MQTT::Publish& pub) {
// In order to republish this payload, a copy must be made
// as the orignal payload buffer will be overwritten whilst
// constructing the PUBLISH packet.
// Copy the payload to a new message
MQTT::Publish newpub("outTopic", pub.payload(), pub.payload_len());
client.publish(newpub);
Serial.begin(115200); // Serial is used to view Analog out
// Analog and digital pins should both be set as inputs:
// pinMode(PIR_AOUT, INPUT);
pinMode(PIR_DOUT, INPUT);
pinMode(RELAY_PIN_1, OUTPUT);
digitalWrite(RELAY_PIN_1, LOW);
// Configure the motion indicator LED pin as an output
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, LOW); // Turn the LED off
if (WiFi.status() != WL_CONNECTED) {
Serial.print("Connecting to ");
Serial.print(ssid);
Serial.println("...");
WiFi.begin(ssid, pass);
if (WiFi.waitForConnectResult() != WL_CONNECTED)
return;
Serial.println("WiFi connected");
if (WiFi.status() == WL_CONNECTED) {
if (!client.connected()) {
if (client.connect("arduinoClient")) {
client.set_callback(callback);
// Read OUT pin, and set onboard LED to mirror output
readDigitalValue();
if (client.connected())
client.loop();
void readDigitalValue()
// The OpenPIR's digital output is active high
int motionStatus = digitalRead(PIR_DOUT);
// If motion is detected, turn the onboard LED on:
if (motionStatus == HIGH){
motionStatus = 1;
//Serial.print(motionStatus);
digitalWrite(LED_PIN, HIGH);
digitalWrite(RELAY_PIN_1, HIGH);
//Sending value to OpenHab with MQTT
Serial.print("The value of motionStatus is: ");
Serial.println(motionStatus);
Serial.print("Sending PIR state ");
Serial.println(presence[motionStatus]);
String pubString = String(presence[motionStatus]);
pubString.toCharArray(message_buff, pubString.length()+1);
client.publish("Boubounouche/Halloween/PIR", message_buff);
delay (10000); // Smoke Machine ON
//trigger = !trigger; // trigger is true
motionStatus = 0;
delay(10000);
else // Otherwise turn the LED off:
