MQTT refusing MKR 1400 connections
I am trying to connect to a MQTT server with my couple year old MKR 1400 (not sure how old exactly). I got the GSMSSLWebClient example working by editing line 124 of GSMClient.cpp to
MODEM.send("AT+USECPRF=0");
The code I am trying to get to work is an edited version of the ArduinoMQTTClient library example WiFiSimpleSender.
My server is getting the message, but it refuses the connection saying
1702044025: Client connection from 195.226.133.56 failed: error:0A0000C1:SSL routines::no shared cipher.
My previous tests with the MKR 1010 works, so I think it is something to do with the code on the GSM side. I am guessing I don't have the right SSL certificates?
The server uses LetsEncrypt.
Here is the code too:
  ArduinoMqttClient - WiFi Simple Sender
  This example connects to a MQTT broker and publishes a message to
  a topic once a second.
  The circuit:
  - Arduino MKR 1000, MKR 1010 or Uno WiFi Rev2 board
  This example code is in the public domain.
#include <ArduinoMqttClient.h>
#include <MKRGSM.h>
#include "arduino_secrets.h"
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
const char PINNUMBER[]     = SECRET_PINNUMBER;
// APN data
const char GPRS_APN[]      = SECRET_GPRS_APN;
const char GPRS_LOGIN[]    = SECRET_GPRS_LOGIN;
const char GPRS_PASSWORD[] = SECRET_GPRS_PASSWORD;
GSMSSLClient client;
GPRS gprs;
GSM gsmAccess;
MqttClient mqttClient(client);
const char broker[] = "*******";
int        port     = 8883;
const char topic[]  = "Tempdata";
const long interval = 15000;
unsigned long previousMillis = 0;
float SERIESRESISTOR = 9.87;
float TEMPERATURENOMINAL = 25.0;
float BCOEFFICIENT = 3540.0;
float thermistor = 0.0;
float THERMISTORNOMINAL = 10;
  //Initialize serial and wait for port to open:
  Serial.println("Starting Arduino web client.");
  // connection state
  bool connected = false;
  // After starting the modem with GSM.begin()
  // attach the shield to the GPRS network with the APN, login and password
  while (!connected) {
    if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &&
        (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)) {
      connected = true;
      Serial.println("Not connected");
  Serial.println("You're connected to the network");
  // You can provide a unique client ID, if not set the library uses Arduino-millis()
  // Each client must have a unique client ID
  mqttClient.setId("pump-house-gsm");
  // You can provide a username and password for authentication
  //mqttClient.setUsernamePassword("****", "****");
  mqttClient.setConnectionTimeout(30000);
  Serial.print("Attempting to connect to the MQTT broker: ");
  Serial.println(broker);
  if (!mqttClient.connect(broker, port)) {
    Serial.print("MQTT connection failed! Error code = ");
    Serial.println(mqttClient.connectError());
    while (1);
  Serial.println("You're connected to the MQTT broker!");
  // set analog resulotion to 12
  analogReadResolution(12);
  // call poll() regularly to allow the library to send MQTT keep alives which
  // avoids being disconnected by the broker
  mqttClient.poll();
  // to avoid having delays in loop, we'll use the strategy from BlinkWithoutDelay
  // see: File -> Examples -> 02.Digital -> BlinkWithoutDelay for more info
  if (currentMillis - previousMillis >= interval) {
    /*Read analog outputof NTC module,
     i.e the voltage across the thermistor */
    float average = ((float)analogRead(A0) / 4095.0) * 3.3;
    average = (average * SERIESRESISTOR) / (3.3 - average);
    Serial.print("Thermistor resistance ");
    Serial.println(average);
    float steinhart;
    steinhart = average / THERMISTORNOMINAL;     // (R/Ro)
    steinhart = log(steinhart);                  // ln(R/Ro)
    steinhart /= BCOEFFICIENT;                   // 1/B * ln(R/Ro)
    steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
    steinhart = 1.0 / steinhart;                 // Invert
    steinhart -= 273.15;                         // convert absolute temp to C
    Serial.print("Temperature ");
    Serial.print(steinhart);
    Serial.println(" *C");
    // save the last time a message was sent
    Serial.print("Sending message to topic: ");
    Serial.println(topic);
    Serial.print("The temperature is");
    Serial.println(thermistor);
    // send message, the Print interface can be used to set the message contents
    mqttClient.beginMessage(topic);
    mqttClient.print("The temperature is ");
    mqttClient.print(steinhart);
    mqttClient.endMessage();
Same guessing here. Why not try first unencrypted mqqt?
Hey.
I've got the unencrypted version working right now, but eventually would like to get the SSL version going.
I should probably just go learn more about SSL and such so I can better troubleshoot this. Anyone have any recommendations for that or a solution to the original problem.
Cheers,
Hey
Works like a breeze:
If you have your own MQTT Broker, use a trusted certificate (Let's encrypt in my case)
Upload the SSL public key to the MKR with the Arduino IDE 2 (E.g. mqtt.exampleserver.com:8883)
My task/question for now:
I want to make a OTA firmware update, is there a way to insert a SSL certificate over the sketch or is there a way to provide the SLL public key within the sketch, anyone?
