Mqtt return value is -1 (arduino mkr wifi 1010 + microsoft azure iot hub
// Read temperature and humidity data from an Arduino MKR1000 or MKR1010 device using a DHT11/DHT22 sensor.
// The data is then sent to Azure IoT Central for visualizing via MQTT
// See the readme.md for details on connecting the sensor and setting up Azure IoT Central to recieve the data.
#include <avr/dtostrf.h>
#include <stdarg.h>
#include <time.h>
#include <SPI.h>
#include <WiFiNINA.h>
#include <WiFiUdp.h>
#include <RTCZero.h>
#include <SimpleDHT.h>
/* You need to go into this file and change this line from:
#define MQTT_MAX_PACKET_SIZE 128
to:
#define MQTT_MAX_PACKET_SIZE 2048
#include <PubSubClient.h>
// change the values for Wi-Fi, Azure IoT Central device, and DHT sensor in this file
#include "./configure.h"
// this is an easy to use NTP Arduino library by Stefan Staub - updates can be found here GitHub - sstaub/NTP: NTP library for Arduino framework
#include "./ntp.h"
#include "./sha256.h"
#include "./base64.h"
#include "./parson.h"
#include "./morse_code.h"
#include "./utils.h"
int getHubHostName(char scopeId, char deviceId, char* key, char *hostName);
enum dht_type {simulated, dht22, dht11};
#if defined DHT22_TYPE
SimpleDHT22 dhtSensor(pinDHT);
dht_type dhtType = dht22;
#elif defined DHT11_TYPE
SimpleDHT11 dhtSensor(pinDHT);
dht_type dhtType = dht11;
#else
dht_type dhtType = simulated;
#endif
String iothubHost;
String deviceId;
String sharedAccessKey;
WiFiSSLClient wifiClient;
PubSubClient *mqtt_client = NULL;
bool timeSet = false;
bool wifiConnected = false;
bool mqttConnected = false;
time_t this_second = 0;
time_t checkTime = 1300000000;
#define TELEMETRY_SEND_INTERVAL 5000 // telemetry data sent every 5 seconds
#define PROPERTY_SEND_INTERVAL 15000 // property data sent every 15 seconds
#define SENSOR_READ_INTERVAL 2500 // read sensors every 2.5 seconds
long lastTelemetryMillis = 0;
long lastPropertyMillis = 0;
long lastSensorReadMillis = 0;
float tempValue = 0.0;
float humidityValue = 0.0;
int dieNumberValue = 1;
// MQTT publish topics
static const char PROGMEM IOT_EVENT_TOPIC[] = "devices/{device_id}/messages/events/";
static const char PROGMEM IOT_TWIN_REPORTED_PROPERTY[] = "$iothub/twin/PATCH/properties/reported/?$rid={request_id}";
static const char PROGMEM IOT_TWIN_REQUEST_TWIN_TOPIC[] = "$iothub/twin/GET/?$rid={request_id}";
static const char PROGMEM IOT_DIRECT_METHOD_RESPONSE_TOPIC[] = "$iothub/methods/res/{status}/?$rid={request_id}";
// MQTT subscribe topics
static const char PROGMEM IOT_TWIN_RESULT_TOPIC[] = "$iothub/twin/res/#";
static const char PROGMEM IOT_TWIN_DESIRED_PATCH_TOPIC[] = "$iothub/twin/PATCH/properties/desired/#";
static const char PROGMEM IOT_C2D_TOPIC[] = "devices/{device_id}/messages/devicebound/#";
static const char PROGMEM IOT_DIRECT_MESSAGE_TOPIC[] = "$iothub/methods/POST/#";
int requestId = 0;
int twinRequestId = -1;
// create a WiFi UDP object for NTP to use
WiFiUDP wifiUdp;
// create an NTP object
NTP ntp(wifiUdp);
// Create an rtc object
RTCZero rtc;
#include "./iotc_dps.h"
// get the time from NTP and set the real-time clock on the MKR10x0
void getTime() {
Serial.println(F("Getting the time from time service: "));
ntp.begin();
ntp.update();
Serial.print(F("Current time: "));
Serial.print(ntp.formattedTime("%d. %B %Y - "));
Serial.println(ntp.formattedTime("%A %T"));
rtc.begin();
rtc.setEpoch(ntp.epoch());
timeSet = true;
void acknowledgeSetting(const char* propertyKey, const char* propertyValue, int version) {
// for IoT Central need to return acknowledgement
const static char* PROGMEM responseTemplate = "{"%s":{"value":%s,"statusCode":%d,"status":"%s","desiredVersion":%d}}";
char payload[1024];
sprintf(payload, responseTemplate, propertyKey, propertyValue, 200, F("completed"), version);
Serial_printf("Sending acknowledgement: %s\n\n", payload);
String topic = (String)IOT_TWIN_REPORTED_PROPERTY;
char buff[20];
topic.replace(F("{request_id}"), itoa(requestId, buff, 10));
mqtt_client->publish(topic.c_str(), payload);
requestId++;
void handleDirectMethod(String topicStr, String payloadStr) {
String msgId = topicStr.substring(topicStr.indexOf("$RID=") + 5);
String methodName = topicStr.substring(topicStr.indexOf(F("$IOTHUB/METHODS/POST/")) + 21, topicStr.indexOf("/?$"));
Serial_printf((char*)F("Direct method call:\n\tMethod Name: %s\n\tParameters: %s\n"), methodName.c_str(), payloadStr.c_str());
if (strcmp(methodName.c_str(), "ECHO") == 0) {
// acknowledge receipt of the command
String response_topic = (String)IOT_DIRECT_METHOD_RESPONSE_TOPIC;
char buff[20];
response_topic.replace(F("{request_id}"), msgId);
response_topic.replace(F("{status}"), F("200")); //OK
mqtt_client->publish(response_topic.c_str(), "");
    // output the message as morse code
    JSON_Value *root_value = json_parse_string(payloadStr.c_str());
    JSON_Object *root_obj = json_value_get_object(root_value);
    const char* msg = json_object_get_string(root_obj, "displayedValue");
    morse_encodeAndFlash(msg);
    json_value_free(root_value);
void handleCloud2DeviceMessage(String topicStr, String payloadStr) { // C2D 设备消息
Serial_printf((char*)F("Cloud to device call:\n\tPayload: %s\n"), payloadStr.c_str());
void handleTwinPropertyChange(String topicStr, String payloadStr) {
// read the property values sent using JSON parser
JSON_Value root_value = json_parse_string(payloadStr.c_str());
JSON_Object root_obj = json_value_get_object(root_value);
const char
propertyKey = json_object_get_name(root_obj, 0);
double propertyValueNum;
double propertyValueBool;
double version;
if (strcmp(propertyKey, "fanSpeed") == 0 || strcmp(propertyKey, "setVoltage") == 0 || strcmp(propertyKey, "setCurrent") == 0 || strcmp(propertyKey, "activateIR") == 0) {
JSON_Object
valObj = json_object_get_object(root_obj, propertyKey);
if (strcmp(propertyKey, "activateIR") == 0) {
propertyValueBool = json_object_get_boolean(valObj, "value");
propertyValueNum = json_object_get_number(valObj, "value");
version = json_object_get_number(root_obj, "$version");
char propertyValueStr[8];
if (propertyValueBool) {
strcpy(propertyValueStr, "true");
strcpy(propertyValueStr, "false");
itoa(propertyValueNum, propertyValueStr, 10);
Serial_printf("\n%s setting change received with value: %s\n", propertyKey, propertyValueStr);
acknowledgeSetting(propertyKey, propertyValueStr, version);
// callback for MQTT subscriptions
void callback(char* topic, byte* payload, unsigned int length) {
String topicStr = (String)topic;
topicStr.toUpperCase();
String payloadStr = (String)((char*)payload);
payloadStr.remove(length);
if (topicStr.startsWith(F("$IOTHUB/METHODS/POST/"))) { // direct method callback
    handleDirectMethod(topicStr, payloadStr);
} else if (topicStr.indexOf(F("/MESSAGES/DEVICEBOUND/")) > -1) { // cloud to device message
    handleCloud2DeviceMessage(topicStr, payloadStr);
} else if (topicStr.startsWith(F("$IOTHUB/TWIN/PATCH/PROPERTIES/DESIRED"))) {  // digital twin desired property change
    handleTwinPropertyChange(topicStr, payloadStr);
} else if (topicStr.startsWith(F("$IOTHUB/TWIN/RES"))) { // digital twin response
    int result = atoi(topicStr.substring(topicStr.indexOf(F("/RES/")) + 5, topicStr.indexOf(F("/?$"))).c_str());
    int msgId = atoi(topicStr.substring(topicStr.indexOf(F("$RID=")) + 5, topicStr.indexOf(F("$VERSION=")) - 1).c_str());
    if (msgId == twinRequestId) {
        // twin request processing
        twinRequestId = -1;
        // output limited to 128 bytes so this output may be truncated
        Serial_printf((char*)F("Current state of device twin:\n\t%s"), payloadStr.c_str());
        if (result >= 200 && result < 300) {
            Serial_printf((char*)F("--> IoT Hub acknowledges successful receipt of twin property: %d\n"), msgId);
            Serial_printf((char*)F("--> IoT Hub could not process twin property: %d, error: %d\n"), msgId, result);
} else { // unknown message
    Serial_printf((char*)F("Unknown message arrived [%s]\nPayload contains: %s"), topic, payloadStr.c_str());
// connect to Azure IoT Hub via MQTT
void connectMQTT(String deviceId, String username, String password) {
mqtt_client->disconnect();
Serial.println(F("Starting IoT Hub connection"));
int retry = 0;
while(retry < 10 && !mqtt_client->connected()) {
    if (mqtt_client->connect(deviceId.c_str(), username.c_str(), password.c_str())) {
            Serial.println(F("===> mqtt connected"));
            mqttConnected = true;
        Serial.print(F("---> mqtt failed, rc="));
        Serial.println(mqtt_client->state());
        delay(2000);
        retry++;
// create an IoT Hub SAS token for authentication
String createIotHubSASToken(char *key, String url, long expire){
url.toLowerCase();
String stringToSign = url + "\n" + String(expire);
int keyLength = strlen(key);
int decodedKeyLength = base64_dec_len(key, keyLength);
char decodedKey[decodedKeyLength];
base64_decode(decodedKey, key, keyLength);
Sha256 *sha256 = new Sha256();
sha256->initHmac((const uint8_t*)decodedKey, (size_t)decodedKeyLength);
sha256->print(stringToSign);
char* sign = (char*) sha256->resultHmac();
int encodedSignLen = base64_enc_len(HASH_LENGTH);
char encodedSign[encodedSignLen];
base64_encode(encodedSign, sign, HASH_LENGTH);
delete(sha256);
return (char*)F("SharedAccessSignature sr=") + url + (char*)F("&sig=") + urlEncode((const char*)encodedSign) + (char*)F("&se=") + String(expire);
// reads the value from the DHT sensor if present else generates a random value
void readSensors() {
dieNumberValue = random(1, 7);
#if defined DHT11_TYPE || defined DHT22_TYPE
int err = SimpleDHTErrSuccess;
if ((err = dhtSensor.read2(&tempValue, &humidityValue, NULL)) != SimpleDHTErrSuccess) {
    Serial_printf("Read DHT sensor failed (Error:%d)", err);
    tempValue = -999.99;
    humidityValue = -999.99;
#else
tempValue = random(0, 7500) / 100.0;
humidityValue = random(0, 9999) / 100.0;
#endif
// uncomment this line to add a small delay to allow time for connecting serial moitor to get full debug output
// delay(5000);
char DEVICE_NAME[] = "MKR 1010";
Serial_printf((char*)F("Hello, starting up the %s device\n"), DEVICE_NAME);
// seed pseudo-random number generator for die roll and simulated sensor values
randomSeed(millis());
// attempt to connect to Wifi network:
Serial.print((char*)F("WiFi Firmware version is "));
Serial.println(WiFi.firmwareVersion());
int status = WL_IDLE_STATUS;
while ( status != WL_CONNECTED) {
    Serial_printf((char*)F("Attempting to connect to Wi-Fi SSID: %s \n"), wifi_ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(wifi_ssid, wifi_password);
// get current UTC time
getTime();
Serial.println("Getting IoT Hub host from Azure IoT DPS");
deviceId = iotc_deviceId;
sharedAccessKey = iotc_deviceKey;
char hostName[64] = {0};
getHubHostName((char*)iotc_scopeId, (char*)iotc_deviceId, (char*)iotc_deviceKey, hostName);
iothubHost = hostName;
// create SAS token and user name for connecting to MQTT broker
String url = iothubHost + urlEncode(String((char*)F("/devices/") + deviceId).c_str());
char *devKey = (char *)sharedAccessKey.c_str();
long expire = rtc.getEpoch() + 864000;
String sasToken = createIotHubSASToken(devKey, url, expire);
String username = iothubHost + "/" + deviceId + (char*)F("/api-version=2016-11-14");
// connect to the IoT Hub MQTT broker
wifiClient.connect(iothubHost.c_str(), 8883);
mqtt_client = new PubSubClient(iothubHost.c_str(), 8883, wifiClient);
connectMQTT(deviceId, username, sasToken);
mqtt_client->setCallback(callback);
// add subscriptions
mqtt_client->subscribe(IOT_TWIN_RESULT_TOPIC);  // twin results
mqtt_client->subscribe(IOT_TWIN_DESIRED_PATCH_TOPIC);  // twin desired properties
String c2dMessageTopic = IOT_C2D_TOPIC;
c2dMessageTopic.replace(F("{device_id}"), deviceId);
mqtt_client->subscribe(c2dMessageTopic.c_str());  // cloud to device messages
mqtt_client->subscribe(IOT_DIRECT_MESSAGE_TOPIC); // direct messages
// request full digital twin update
String topic = (String)IOT_TWIN_REQUEST_TWIN_TOPIC;
char buff[20];
twinRequestId = requestId;
requestId++;
mqtt_client->publish(topic.c_str(), "");
// initialize timers
lastTelemetryMillis = millis();
lastPropertyMillis = millis();
// main processing loop
// give the MQTT handler time to do it's thing
mqtt_client->loop();
// read the sensor values
if (millis() - lastSensorReadMillis > SENSOR_READ_INTERVAL) {
    readSensors();
    lastSensorReadMillis = millis();
// send telemetry values every 5 seconds
if (mqtt_client->connected() && millis() - lastTelemetryMillis > TELEMETRY_SEND_INTERVAL) {
    Serial.println(F("Sending telemetry ..."));
    String topic = (String)IOT_EVENT_TOPIC;
    topic.replace(F("{device_id}"), deviceId);
    char buff[10];
    String payload = F("{\"temp\": {temp}, \"humidity\": {humidity}}");
    payload.replace(F("{temp}"), dtostrf(tempValue, 7, 2, buff));
    payload.replace(F("{humidity}"), dtostrf(humidityValue, 7, 2, buff));
    Serial_printf("\t%s\n", payload.c_str());
    mqtt_client->publish(topic.c_str(), payload.c_str());
// send a property update every 15 seconds
if (mqtt_client->connected() && millis() - lastPropertyMillis > PROPERTY_SEND_INTERVAL) {
    Serial.println(F("Sending digital twin property ..."));
    char buff[20];
    String payload = F("{\"dieNumber\": {dieNumberValue}}");
    payload.replace(F("{dieNumberValue}"), itoa(dieNumberValue, buff, 10));
    requestId++;
why did you post in the Chinese section and what is your question.
Hello, do yourself a favour and please read How to get the best out of this forum and edit (small pencil under your post) accordingly (including code tags and necessary documentation for your ask).
until further modification, I've moved your post to the bar as there is no clear intent.
I was sorry to publish in the wrong area, this is my first time to use this and i already fix this topic that the code didnot have any program mistake but it always return the value of -1.
Please add code tags and a clear description of what the code does or does not, the intent, describe the circuit… make it a full question if you want any answer.
