MQTT - returning strings / char arrays from callback() to loop
Executive Summary: I would like to make an MQTT message that I retrieved using callback() available inside my loop (from where it is then displayed on a giant NeoPixel array). Overall, this will be a neat projet! All will make sense once you glance at the code snippets.
Background: Last month I built the coolest monster display ever using NeoPixels
and it works like a charm. Lots of fun; highly recommendable project. But the displayed txt is hardcoded into the program.
I want to be able allow my guests to change the displayed text on this monster.
I settled upon using MQTT - useful to learn about that anyway. Set up my own broker on my NAS; I can pass messages around just fine. Did all my homework.
But I can't transfer the MQTT txt into my main program. :confused:
My sketch is pretty long; I can post it if wanted (you would probably get bugged down in the weeds)
Here are the salient parts:
    client.loop();   // grab any new stringText from MQTT broker
                     // can display it just fine inside the callback function.
  // want to have *m passed back from the callback function so that the displayed text can be changed
    const char *m = "TEST NUMBER 5";  // Still hardwired. Bummer. Want this under external control!
                                      //Note that text may be quite long (1000+ characters)
    while (*m) {                      // while loop is black magic. Josh is a wizard!
       for( uint8_t step=0; step<FONT_WIDTH+INTERCHAR_SPACE  ; step++ ) {
          cli();
          sendString( m , step , 0x01, 0x00, 0x02 );
          sei();
       m++;
In the code, client.loop(); seems to really only call callback(). Not sure I understand the details, but it works, so I'll take it.
Anyway, the callback function itself was taken from the MQTT library GitHub - knolleary/pubsubclient: A client library for the Arduino Ethernet Shield that provides support for MQTT.
It looks like this: (NOTE: I already figured out how to change char array in it to a string!)
void callback(char* topic, byte* payload, unsigned int length) {
// checks if message has arrived & displays it: (straight from the MQTT library)
// next 4 lines were in the library - seems to be a very complicated way of doing this?
//  for (int i=0;i<length;i++) {
//    Serial.print((char)payload[i]);
//  Serial.println();
// here is how to change that into a char - makes it easier in my mind.
  payload[length] = '\0';    // add a null to terminate
  Serial.println("Re-cast as *string - is this this what I want? :");
  char *m = (char *) payload;
  Serial.print(m);
Anytime I publish a new message, it pops up in my serial display. Cool.
What I want to achieve is this: every time there is a new message coming in from MQTT, change what is displayed on the NEOPIXEL display...
Or, pass *m from the callback function into loop
Been banging my head against this too long... any help is appreciated!
--cut here--
Actually, what I REALLY want is
-have an array of, say, 5 messages (A,B,C,D,E) that are displayed one after the other (I already know how to do that)
-MQTT a new message in; replace old message A with this new one (call it A'). Now display A', B, C, D, E
-MQTT a second message in; replace old message B with this newer one (B'). displaying A', B', C, D, E
-send more and more; after I am at A', B', C', D', E', the next MQTT messages will be A" so that I display A", B', C', D', E'.
And so on... But I have that under control (I think).
--cut here--
So it all hinges on my being able to "extract" the newest MQTT message from the callback function, which I am stumped with.
Thanks!
(using UNO with Ethernet shield)
Since you have only published bits of your code, it is a bit difficult to see where your problem is. In general, if you want to pass data from a function so it is available in the loop(), you set a global variable (maybe declared as volatile if the function is called by an interrupt service routine. In the loop() you simply use that global variable.
You can't pass data from a function to another function, except when you call a function. Your callback function can not pass data to loop(), because loop() is not what called it.
You can put data in global variables, in the callback function, and use the data in the loop() function.
