MQTT Sender gets stucks
Hello Folks,
I have a problem with a lolin_s2_mini microcontroller which acts as a PIR Sensor and Publishes over MQTT.
It gets stuck once every 24h, and my lights do not turn on anymore.
Pressing reset and it works again.
The code is very straight forward:
#include <Arduino.h>
#include <WiFi.h>
#include <PubSubClient.h>
#include "config.h"
#define COOLDOWN_WAIT 5000 // Wait for 5 seconds
#define DURATION_PUBLISH_INTERVAL 1000 // Publish duration at most every 1 second
#define BUILTIN_LED 2 // Change this to the pin number of your board's built-in LED
WiFiClient espClient;
PubSubClient client(espClient);
unsigned long motionStartTime = 0;
unsigned long lastDurationPublishTime = 0;
bool motionDetected = false;
void setup_wifi() {
  delay(10);
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
void reconnect() {
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    if (client.connect("ESP8266Client", mqtt_username, mqtt_password)) {
      Serial.println("connected");
      // Flash the built-in LED 3 times after connecting to the MQTT broker
      for (int i = 0; i < 3; i++) {
        digitalWrite(BUILTIN_LED, LOW); // Turn on the LED
        delay(200);
        digitalWrite(BUILTIN_LED, HIGH); // Turn off the LED
        delay(200);
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      delay(5000);
  pinMode(BUILTIN_LED, OUTPUT);
  setup_wifi();
  client.setServer(mqtt_server, mqtt_port);
  pinMode(PIR_PIN, INPUT);
  if (!client.connected()) {
    reconnect();
  client.loop();
  int pirState = digitalRead(PIR_PIN);
  if (pirState == HIGH && !motionDetected) {
    motionDetected = true;
    motionStartTime = millis();
    client.publish("PIR/Gang/state", "true");
  if (motionDetected && millis() - lastDurationPublishTime >= DURATION_PUBLISH_INTERVAL) {
    int duration = (millis() - motionStartTime) / 1000;
    char durationMsg[10];
    sprintf(durationMsg, "%d", duration);
    client.publish("PIR/Gang/duration", durationMsg);
    lastDurationPublishTime = millis();
  if (pirState == LOW && motionDetected) {
    unsigned long cooldownStart = millis();
    while (millis() - cooldownStart < COOLDOWN_WAIT) {
      if (digitalRead(PIR_PIN) == HIGH) {
        return;
    client.publish("PIR/Gang/state", "false");
What is the issue here?
Many thanks in advance!
do you see the output of this part of the code in the serial monitor ?
void reconnect() {
    if (client.connect("S2_Gang", mqtt_username, mqtt_password)) {
      flashLed(3, 300, 300);
      flashLed(2, 100, 400); // Blink twice if failed to connect to MQTT broker
      delay(2000);
Whenever the arduino is stuck, it is blinking twice and rests for 10s or so. So it must be part of the else in void reconnect().
I will try to read out the Serial the next time is see it in this state.
09:50:06.673 -> failed, rc=-2 try again in 5 seconds
09:50:09.691 -> Attempting MQTT connection...failed, rc=-2 try again in 5 seconds
09:50:19.685 -> Attempting MQTT connection...failed, rc=-2 try again in 5 seconds
09:50:29.683 -> Attempting MQTT connection.....
(PRESS ON RESET BUTTON)
09:50:37.799 -> WiFi connected
09:50:37.799 -> IP address:
09:50:37.799 -> 192.168.0.196
09:50:37.799 -> Attempting MQTT connection...connected
possibly your DHCP lease expires and your board's IP needs changing - so needs a reconnect to the WiFi infrastructure?
