Hi, I am currently writing a code to control and RGB led strip with a four channel relay using MQTT.
Can someone check whether my code is valid? Any help is appreciated
/Code is using a Wemos D1 mini/
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <WiFiClientSecure.h>
// Connect to the WiFi
const char* ssid = "ssid";
const char* password = "pswd";
const char* mqtt_server = "broker.mqttdashboard.com";
WiFiClient espClient;
PubSubClient client(espClient);
//Pins are connected to relays
const int RED_PIN = 12; //D6: Red Pin
const int GREEN_PIN = 14; //D5: Green Pin
const int BLUE_PIN = 13; //D7: Blue Pin
// The function below connects your NodeMCU to the wireless network
void setup_wifi(){
Serial.print("connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
delay(2000);
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
char receivedChar = (char)payload[i];
if(receivedChar=='0'){
Serial.print("Relays On");
OnRelays();
ColourChange();
if(receivedChar=='1'){
Serial.print("Relays Off");
OffRelays();}
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.println("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("Reception")) { // "explicit name for each client"
Serial.println("Reception is connected to MQTT server");
// ... and subscribe to topic
client.subscribe("RGB/Output");//Topic subscribed to
Serial.print("Failed to connect to MQTT...");
Serial.println("Attempting to connect again in 3 seconds.");
// Wait seconds before retrying
delay(3000);
//Led starts by lighting up Green
void InitialLedState(){
digitalWrite(RED_PIN, HIGH);
digitalWrite(GREEN_PIN, LOW);
digitalWrite(BLUE_PIN, HIGH);
client.publish("RGB/Output", "Green");
void OnRelays(){
digitalWrite(RED_PIN, LOW);
digitalWrite(BLUE_PIN, LOW);
void OffRelays(){
digitalWrite(GREEN_PIN, HIGH);
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
pinMode(RED_PIN, OUTPUT);
pinMode(GREEN_PIN, OUTPUT);
pinMode(BLUE_PIN, OUTPUT);
InitialLedState();
if (!client.connected()) {
reconnect();
client.loop();
void RGB_color(int red_light_value, int green_light_value, int blue_light_value)
analogWrite(RED_PIN, red_light_value);
analogWrite(GREEN_PIN, green_light_value);
analogWrite(BLUE_PIN, blue_light_value);
void ColourChange(){
RGB_color(255, 0, 0); // Red
RGB_color(0, 255, 0); // Green
RGB_color(0, 0, 255); // Blue
RGB_color(255, 255, 125); // Raspberry
RGB_color(0, 255, 255); // Cyan
RGB_color(255, 0, 255); // Magenta
RGB_color(255, 255, 0); // Yellow
RGB_color(255, 255, 255); // White
